I know a covered box would help, but due to the 'particular' needs of the two oldest cats, we have to use a large, deep box without a cover. I decided something to reduce the dust during use would go a long way toward making my life easier - so through trial and error, this is what I came up with. (Sorry for the grainy pics, my camera is getting old. How great would it be to win one ;-) ) I finished the project without taking pics, so I am recreating the bits I can.
Here it is - my first 'ible
Supplies:
- CPU cooling fans (2) $6.00
- Wall wart with 12v output (or whatever your fans run on) $8.00
- TIP31 transistor $0.47
- Motion activated light $8.00 (mine is battery powered)
- Filter material (I used the foam stuff for a window A/C unit) $1.00
- Container for your fans (I used the Ziploc large rectangle food storage box) $2.00
Remove these ads by
Signing UpStep 1The fans
Attach the wires from the 2 fans together, red to red and black to black (solder or wire nuts, noting they will have an additional wire attached in step 3). Leave as much extra wire as possible to allow positioning later (or cut it close if you have already measured your box)
But ... what the heck is a wall "wart"????
http://www.instructables.com/id/Hobby-Electronics-Power-Supplies-Part-1-Wall-Wart/
Handy & cheap
Appreciate your note. Boy, did I learn a lot today on the site, my first day, too!
An alternative may be to use an alarm motion sensor. These are usually designed for 12 volts, so you could just go from the power supply, through the sensor to the fans.
(Love those big tubs as litter boxes, keeps them from scattering the litter around the floor, as well)
Filter ($14.99)
http://www.homedepot.ca/product/activated-carbon-pre-filter/918286
120mm to 80mm fan adapter ($4.99)
http://www.memoryexpress.com/Products/PID-MX20843(ME).aspx
120mm Grill which holds the filter in place ($3.99)
http://www.memoryexpress.com/Products/PID-MX28858(ME).aspx
And of course any 80mm computer fan on the other side of the 80-120mm adapter - I use a 3 setting fan, but usually have it on low.
The filter is then about 1/2" away from the fan and won't get caught up.
As well, you get ~30 120mm squares out of that one Honeywell filter!
I should do an instructable, but yours covers it way better as my fans are always on...
Much thanks!
I considered the "always on" option when my trigger refused to work LOL, and it draws so little power I don't think it would be a problem. Still, I'm glad I got the motion sensor to work as planned.
I hadn't originally planned on the carbon filter, as odor was not an issue when I started the build. When the kitten came along, though, whew! Stinky. When it comes time for a replacement filter for the front, I may look into the type you used - catch the dust & the smell at one time :-D
Thanks for reading & commenting ( you are my first ;-) )
I set the fans to suck IN through the filter, as then you get a greater surface area...
The active carbon destinkifier helps a lot and totally kills the smell even when they get wet food or eat a mouse / bird / grasshoppers ?!
And that grill catches a lot of the dust before it even hits the filter :D
Much thanks !
