Knetix Magnum (killerk's Perfected)
2,140
7
18
Posted in PlayKnex
Introduction: Knetix Magnum (killerk's Perfected)
About: Sometimes it takes a man to push beyond what he thinks is possible before he realizes that possibility is a mere conception of the mind. Once that barrier is broken, the mind is no longer a hindrance, but h...
Here it is! The first version of killerk's magnum to have a functioning magazine. I was messin around with the magnum and figured out a way to pt on a magazine as well as make it shoot rods, instead of the rod with the red connector. I have also improved the trigger.
Pros.
-Improved trigger
-50-60 foot range
-9 shot magazine
-contained firing pin (so theres no annoying thing sticking out when u pull back the pin)
-good sight
Cons.
-A little flimsy at the middle
-only accurate at short range
ENJOY!
Step 1: Support Plates
A pretty easy step. These are what holds the front of the gun together and makes it a little stronger.
Step 2: The Magazine and Mag Ram
This mag holds 9 blue rods and never jams
Step 3: Upper Body
This the upper part of the body of the gun. At the middle its kind of weak so it would be good if you could come up with a way to make supports for it without getting in the way of the ram handle.
Step 4: Lower Body
This is the lower body (really?). This includes the barrel of the gun as well as the area where the magazine is located.
Step 5: Stock
Fairly easy step. You could really just put any kind of sock on this gun, but this is the one i made. It holds extra ammo and is pretty comfortable.
Step 6: The Trigger
This is the new improved trigger i came up with. I guess u could use the original killerk trigger if you really wanted to, but I prefer this one.
Step 7: Sight
This sight is accurate at close up targets, but not long range ones.
Step 8: Put It Together
Putting all the parts together
Step 9: Adding Rubber Bands
Adding the rubberbands
To load:lift out mag ram and insert blue rods
To fire: pull back ram until you hear a click. Pull trigger.
Enjoy!
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Pocket-Sized Contest
    18 Comments
    instead of putting all that stuff on the magnum could you just attach a magazien to it? if so for killerks magnum notify me thanks :)
    ya-it is good at scaring off little siblings lol
    they dont really like me dat much ne more now dat i started making knex guns
    i guess you could replace some of the blue rods with the white rods, but when u build it, youll find that all the pieces are nessecary
    looks like threes alot of unnecessary pieces.
    sharpen the blue rods. looses a little range, but massively increased dammage.
    sweet! 5*s
    WOAH! Great work. 5* I have to say!
