K'nex - CZ-75 Instructions
1,795
9
30
Posted
Introduction: K'nex - CZ-75 Instructions
Hey guys, and today I bring you instructions for the CZ-75 that was used by the Cezch and Turkish police. It has also been used in several police departments in the USA. There have been many variants with smaller versions, different cartridges and some were adapted to have additional attachments. A selective fire version was introduce in 1992 which include a handgrip which could be hooked onto the front which was in fact a modified magazine for the CZ-75.
Anyway let's talk about the CZ-75, it's not my own design since it does belong to Instructabler The Red Book Of Westmarch as I did follow the pictures that posted of his own K'nex CZ-75 to make this one and of course I have made instructions for it so you can have your very own. The CZ-75 took me 2 hours to build it and this does include making minor tweaks and adjustments to it.
Good Points
· Good Iron Sights
· Removable Magazine
· Comfortable Handgrip
· Very Realistic
Bad Points
· Doesn't Shoot Because It's Just A Model
· Uses Quite A Lot Of Cut Pieces (See Parts List)
Specifications For A Real CZ-75
· Designed - 1975
· Number Built - Over 1,000,000
· Ammo - Mainly 9×19mm Parabellum
· Rate Of Fire - Semi-Automatic
· Powered - Short Recoil and Tilting Barrel
· Magazine - 12 to 26 Round Magazine
· Range - 55 Yards
In Call Of Duty: Zombies, the CZ-75 is available in all Call Of Duty: Black Ops maps where it can be obtained either single or dual wield from the Mystery Box for 950 points. There are two different versions when it is Pack-A-Punched for 5000 points. The single becomes the "Calamity" where you get more damage, more damage, bigger magazine and it becomes fully automatic. The duel wield becomes the "Calamity and Jane" where you get more damage, more ammo, bigger magazine and they become fully automatic. The single CZ-75 had less ammo but has more accuracy where as the duel wield CZ-75 has more ammo but has less accuracy. Speed Cola will cut the reload time to 1 second and it is up to the player to buy Double Tap to increase the rate of fire but you will use more ammo and only way to get more ammo is through a Max Ammo power up.
Also check out my other creations and instructions
https://www.instructables.com/id/Knex-Biplane-Instructions/
https://www.instructables.com/id/Knex-1976-MP5K-Instructions/
https://www.instructables.com/id/My-Knex-Weapons-Of-2013-2014/
https://www.instructables.com/id/Knex-James-Bond-Helicopter-With-Saws/
https://www.instructables.com/id/Knex-Galvaknuckles-Instructions/
https://www.instructables.com/id/Knex-1979-SPAS-12-Instructions/
Step 1: Parts List
If you have any trouble or need more pictures just leave a comment and I will get back you ASAP. I strongly advised you to collect all the pieces before you start building. Also I have added a few notes throughout this instructable to make it more easier to understand something if you run into any difficulty.
Green Rods - 79
White Rods - 16
Blue Rods - 2
Green Connectors - 2
White Connectors - 12
Yellow Connectors - 27
Red Connectors - 4
Light Grey Connectors - 5
Dark Grey Connectors - 9
Orange Connectors - 18
Tan Connectors - 2
Tan Connector (with the little tab cut off) - 3
Y Shaped Black Connectors - 36
Blue 52mm Flexy Rod - 1
Orange 86mm Flexy Rod - 1
Yellow Connector (cut, see step 2) - 3
Red Connector (cut, see step 2) - 2
Red Connector (cut, see step 3) - 2
Orange Connector (cut, see step 3) - 1
1.9cm cut Rods - 8
3.1cm cut Rods - 15
Blue Spacers - 6
Total - 255
Step 2: Barrel & Trigger
Step 3: Handle & Magazine Well
Step 4: Magazine
Step 5: Done
Well done you made it to the end, I do hope you have enjoyed building it.
Zombie Quotes About The Duel Wield CZ-75
"I will be able to take them out gangsta style now"
"Double the pleasure, double the pain, double the damage"
"I will bring the wrath of the emperor down upon them"
Thanks for building it, please leave a comment in the box below and subscribe
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    30 Comments
    nice gun :) Btw you deserved the sub ur ibles are great I'm surprised I haven't found you b4!
    BTW I'm on mobile so I can't reply on profiles
    Ok Linkin, that aint a problem atleast you have replied to me
    Thanks Linkin, anything you like, comment or favourite, it always helps me
    yo man
    still a nice gun
    what ya plannin next??
    Thanks Kona, your not gonna see anything new from me for quite a while since I have just started a new job this week but the good thing is I do get every school holiday off work so will I try and use the time when possible to build and post more either instructions or reviews.
