Knex 4 Speed Manual Transmission With 3D Printed Gears
Introduction: Knex 4 Speed Manual Transmission With 3D Printed Gears
I found a few files online for 3D printed Knex gears because, I was limited to only 3 speeds without using the largest gear; I wanted something compact.
After tinkering with this off and on for 2 months, I think I've got it how I want it.
It features:
+4 non-sequential​ gears
+Smooth shifting
+Achieves the high end and low end of the gear set
+Has a lever for precise gear alignment.
+Able to fit the bulky 2-speed motor
With this post I'm also issuing a challenge. I was not able to achieve the low-geared(big red gear to small tan gear) side of the 3D printed gears' mesh. This means this gear set has a possibility of more than 4 gears, however spacing is an issue. Please repost any modifications or uses for this design and if you are able to add gears.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    need a 20 tooth gear like above. any ideas.
    This is a neat design. :) Did you take any progress photos while you were putting it together?
