K'nex AK-74u
2,770
5
29
Published
Introduction: K'nex AK-74u
About: I have a clones! Clone1: https://www.instructables.com/member/knexgunner7073/ Clone2: https://www.instructables.com/member/knexgunner1234/ Clone3: https://www.instructables.com/member/knexgunner16/ Cl...
This is what I believe to be the first AK-74u On this website. Since I haven't posted any thing in a while I decided to make some thing out of k'nex that I haven't seen yet. So I present to you my new AK-74u. I would like comments that help me improve for the future and not some comments saying the person rates me down because I "enhance" pieces as Perfect Duck I think would say.
Range: about 30-50 ft.
Accuracy: Good
Realistic Stock
Realistic Sights
2 Sights
Step 1: Stock
This is the stock. I'm sorry it seems a little vague.
1. Side view
2. Back View
Step 2: Handle & Trigger
Here you will make the handle and trigger.
1. Make these - these will connect the handle to the rest of the gun.
2. This is the handle and trigger guard it is identical on both sides - don't forget the grey connector in the middle of the handle!
3. This is the trigger - there is a green rod in the taped area and is identical on both sides
4. Attach one of the panels on the handle
5. Attach the other panel on the other side and add the trigger in the appropriate spot
Step 3: Barrel & Reciever
Here is the barrel and reciever.
1. This a side view of the barrel
2. This an under-barrel view.
Step 4: Top Rail and Sights
This is the top rail.
1. Side view of the top rail.
2. Top view of first half of the top rail.
3. Top view of the second half of the top rail.
Step 5: Body & Fake Barrel
This is the body and fake barrel
1. Side view of body.
2. Top view of body.
3. Bottom View of Body
4. Fake barrel
Step 6: Magazine & Firing Pin
This is the Magazine and firing pin.
1. Firing pin
2.Top View of magazine .
3. Angled view of magazine.
4. Another view of magazine.
Step 7: Assembley
Time to assemble the gun.
1. Connect Handle to Stock
2. Connect Barrel to Handle
3. Connect Trigger Guard
4. Connect back part of Top Rail to handle
5. Connect Body to Barrel
6. Connect Connect rest of Top Rail to Body
7. Connect Fake Barrel to Body.
8. Connect the magazine to the gun.
9. Insert firing pin.
Step 8: Rubber Bands & Sights
This show where to hook the rubber bands an TELLS how to use the sights.
1. Unhook the trigger guard and hook rubber band on trigger the re-connect trigger guard.
2. Hook other side of the trigger band on the blue connector on the top rail
3. Unhook the top rail here
4. Hook rubberband on the white connector the hook on firing pin (sorry for no picture) then re-connect the top rail.
**TO USE MAIN SIGHTS**
You line up the grey grey connectors on the blue connectors on the top rail with the tan connectors on the other end of the top rail
** TO USE THE SECONDARY SIGHTS**
You look through the horizontal orange connectors and line up the grey connectors on the side of the orange connector's hole so the Y-connector is in the middle.
    • Clocks Contest
      Clocks Contest
    • Pets Challenge
      Pets Challenge
    • Oil Contest
      Oil Contest
    29 Comments
    the stock is just a frame, fill it up? also nothing that new. PS, my friend also has the exact same T-shirt.
    Fail, the real ak-47u's stock IS a frame.
    necro'ing a post yep
    all the AK systems have interchangeable stocks, so you can basicly put an AR15 or even an ACR style stock on it aslong as it's interchangeable with the AK you're using
    yep ure correct. u even put a real one on the first picture
    This was originally billed as an AK-47, no U at the end.
    i would fill the stock up but it ruins the realisim (see last pic) PS LOL
    I modded it. check it out on my page
    make instructions for it
    Great replica, although there isn't much to compare to lol.
    Yo Man! Great Gun! I tried to build, but due to lack of hinge pieces, I was forced to build a straight, maybe 20 round mag, ultimately leading to a replica M14 EBR, with great looks, but 10-20ft range. My rubberbands suck, so...Yeah... Anyways, 4*!!!
     Looks like a FN SCAR with a Hole in the Stock :P
    looks more like the new version of the AK= the AN-94 pretty nice tho :D 4 stars
    u should make the mag longer. : D .
