K'nex Arcade Coin Pusher Instructable
9,060
15
25
Published
Introduction: K'nex Arcade Coin Pusher Instructable
About: nothing much really.
I have had some requests to create an ible for this coin pusher. I am using a drill as a motor to turn the axle because I don't have a k'nex motor. I am sure that you can easily modify it so you can use a normal K'nex motor. Please rate well and subscribe.
Step 1: The Base
It is simple to make the base just with images.
Step 2: The Axle
1. The product
2.make
3.closer look
4.make
5.make
6.closer look
7.closer look
8.attatch
9.attatch
10.attatch
Step 3: The Coin Pusher
There are 14 of the half-moon and red connecters. Connect the pieces together with green rods. You also need to cut off each end of the 2 red rods so that the fit in the coinpusher without jamming.
1.Product
2.closer look
3.closer look
4.add (the green rod on the left is 6 half-moon connectors in and the green rod on the right is 5 half-moon connectors in. They are 3 half-moons apart.).
Step 4:
1.Product
2.make
3.underneath
4.underneath
5.underneath
6.underneath
7.underneath
8.underneath
9.side
10.other side
11.make-16 long.
12.connect
13.connect. READ (i did this bit wrong. Move all the pieces 1 snowflake to the left). sorry.
Step 5: Connecting
1.place on top
2.connect
3.connect
4.connect
Step 6: Wher You Drop the Coin
1.make
2.other side
3.make
4.make
5.get-missing image so connect the rods to the bottom line of snowflakes on the 2 middle snowflakes, on the top of them, towards the outside.
6.get
7.connect
8.other side
9.connect
10.connect
11.finished
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
    • Microcontroller Contest
    25 Comments
    wow, It took me 2 hours to perfectly re-create and modify the coin pusher from just the slide show...Exactly after I finished it you made an instructable on it, whats your problem
    Maybe it took him 2 hours to make the ible?
    make an outer case for it :3
    Can you make the whole thing bigger and not cut the red rods?
    yeah. definitly. i don't have enough pieces though.
    can you do it with a real motor
    if you can figure out how to put it on.
    This is sweet! I have even made a couple cents off of my brother and sister.
    I am going to try and make this. I am also going to try and make it bigger. I might post the bigger version when I have made it
    Good job! I made one myself too after seeing yours.
    https://www.instructables.com/id/Knex-Coin-Pusher-1/
    I think I'm going to make one too and post the picture when I'm done =]
    Might actually build this.
    Araid u do. It will jam otherwise. sorry.
    rubbish design! looks good though, but you have to cut pieces :( (which i didnt do)
    nice one!
