Knex Ball Machine Separator (8 Outputs)
1,300
6
16
Published
Introduction: Knex Ball Machine Separator (8 Outputs)
About: Hey everyone. I'm Thibault Art and my biggest hobby is to build huge machines in K'nex. I like also to draw a lot and take care of my corn snake. On this page you will find K'nex ball machines, K'nex element...
Hey everyone,
Here are instructions for my best working Knex Ball Separator to date. It's not too difficult to build, no motors are needed and works about 90% of the time when instructions are carefully followed.
You can check out step 1 for the special pieces that you'll need to build this separator. Also 11 Medium yellow (or grey) and 7 small bleu (or brown) gears are needed. If you don't have 11 Med yellow gears, don't worry, you can replace the 7 Med gears in step 9 and 10 with the Med red gears instead.
In step 19 you'll see that a little table needs to be made and fixed underneath the separator. This table puts the separator at an angle of 12 degrees, which is very important! So if you want to use this separator in one of your machines, make sure it stands at an angle of 12 degrees.
You can always watch the video to see how it works.
If there are any complains, problems or questions, feel free to pm me or tell me in the comments below.
Thanks for watching, building,
Thibault Art
btw: Sorry for my bad english, I'm working on it :).
Step 1: Special Pieces You Need:
You'll need 2 of these.
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
Step 11:
Step 12: Very Important Step:
Make sure that all 7 grey connectors attached to the yellow rods are exactly in this position.
Step 13: Another Imprtant Step:
A little bit of space between every grey and oranje connector is highly recommended.
Step 14:
Step 15:
Step 16:
Step 17:
Step 18: Third Important Step:
Make sure that there is 1 red connector going up and 1 down everytime you turn the octagonal wheel. If all 7 red connectors went up and down 1 time after the octagon did 1 complete spin, Congratulations! You placed every single gear perfectly :).
Step 19:
Step 20: Go Ahead and Try It Out!
Step 21: Little Detail:
It's possible that the ball jumps over a red connector. If this is the case, elevate the track just a tiny little bit untill the ball doesn't jump over the connectors anymore.
3 People Made This Project!
  • BBQ Showdown Challenge
  • Creative Misuse Contest
  • Oil Contest
    Oil Contest
16 Discussions
Yes, you can replace all the yellow gears with red ones. Except the 2 gears on step 7. So you'll still need 2 yellow ones.
I'm very sorry for the massive delay. It's coming this weekend without any dought.
Sorry for not posting the smaller separator yet. Things got in my way, but its coming soon.
There is no reset system, When the wheel makes one complete spin it just starts over again. Just like my previous separator that was featured in my Ball Machine Exception you know.
If you really want to find out, you'll have to build it :).
Thanks! Next instructable will be another lift, and after that the second separator you see in the video.
