i made a similar gun but i used a motor to feed about 30 shots in and they do shoot becuse the mortor also releses 1 ruuber band at a time up 2 40 because it jams sometimes so its beast because it empties in about 8 seconds and its light weight like all my knex guns
i'm in mid posting now lol. all i have to post is the barrel. but the barrel uses 4 grey rods with one end chopped off and 2 yellow rods with both ends chopped off. the grey rods make the barrel longer than the longest rod.
ye it is small. i could have made it bigger but that meant a bigger barrel which meant more modded pieces. also, the reason why i made the m1919 is because it's one of the coolest gun's in COD 5. also it uses a chain to shoot like the real one so it feels realistic. anyway i hope your M2 goes well :) do you have any pictures of the work in progress? thanks for rating btw
(i gave it a 4.00, because its too small) Uhh, my M2 is umm. Too small to take pics off. I've started on the handle, and thats it... why you ask? New knife (packaged with the CC) Compact Carbine (slide Action) and Powerful true semi auto I have two of them. The Semi Auto so far is just an idea.
lol it says 3.00 when i look at it. it might be bugged.
anyway where did this come from?
"New knife (packaged with the CC) Compact Carbine (slide Action) and Powerful true semi auto"
are those your new projects? if so sounds cool. will be looking forward to the semi auto. personally i think we have to many bolt action/single shot with mags. i think we knex people need to start on the higher RPM guns. it seems like we're in the early 1900's with k'nex guns. we've only just started making good semi and fully automatic weapons.
there need to be more mech's for these type of guns!!!!
sorry for getting a bit random towards the end =P
BTW are you from the UK? you dont have 2 answer if you dont want to. :)
im in england. i'll be on PSN in a sec, They are new projects, but when you said "we've only just started making good semi and fully automatic weapons." We are NOT GOOD at making Semi automatic weapons. Neither are we THAT good at making automatics If we were good: Semi autos would be real, have easy trigger pull, and shoot thirty feet. Great ones would be compact. Automatics would have chains/magazines that you don't have to spend an hour reloading. Also, they wouldnt jam half as often as they do. So far we have no form of SubMachineGuns. A submachine gun would need to be around the size as my C.C. (about the size of an average qwerty keyboard). They would need to not fire cartridges, and they would need to fire from a magazine like a blue rod mag. Basically to do that, we need an automatic riveter, which would defeat the purpose, because the riveter would become the gun, and the knex would just be an annoying dressing.
but what i mean is that they shoot semi and fully automaticly. they don't shoot with a mechanism like the real one, but neither did the bolt action rifles. our knex guns will never shoot with the same mechanism as real guns, but we can fake it. and that's what we are doing. there are currently 3 ways to shoot a knex gun fully automaticly: chain, gatling & rack & pinion. (chain and gatling gun are pretty much the same.) if we were to find a way to make knex bullets on a chain then we would be able to connect it to the rack & pinion. but the bullets would have to be able to slide off when in the chamber but not while outside the gun on the chain. the rack and pinion method is quite clever. all we need is something that can pull back the firing pin when under a lot of stress from the rubber bands. therefore creating more power and range. the best we can do at the moment are the cyber knex motors. i don't think anyone has tryed the rack and pinion with a cyber knex motor yet. but i do have this weird knex piece i found in my box. it's like a 6 way snowflake made from rods. it might help pull the firing pin back, might not. i will send you a pic if i can. anyway, when i said the rack and pinion mech is clever, it's because it will help in making submachine guns (fake of course) and you might be able to make a ppsh-41 or a thompson out of it. it wouldn't work with an uzi because you will have the mech sticking out the gun lol.
wow that is a lot of writing
i will try to show u a pic of that piece i have ok.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
no say it in english
i know it was english but IT DOESN'T MAKE much SENSE
btw you're name scares me i have a friend on my ps3 called dandan24
i might make a PPSH-41 full auto aswell
my screen name is ZEUS
that thing is sexy
and
