K'nex Brushless Motor Mount and Adapter
653
Posted
Introduction: K'nex Brushless Motor Mount and Adapter
Welcome to my instructable on how to make a brushless motor mount and adapter for k'nex! Using this, we can use brushless motors to drive our k'nex creations!
I built this because I was looking for alternative methods of motorizing k'nex. I had an extra motor lying around and decided to experiment and see how I could incorporate it with k'nex.
This mount and adapter work well with the Tacon Bigfoot 60 brushless motor. I do not know how well this will work with other motors, but it should work with motors of similar size. This motor is designed for use in RC airplanes, but using this mount and adapter we can use it with k'nex.
Benefits of using this over traditional k'nex motors include:
  • Higher torque capacity
  • Higher RPM
  • And variable speed. Speed is controlled through an electronic speed controller which can be controlled with an Arduino or other microcontroller or a RC radio receiver.
Step 1: The Parts List
1 Tacon Bigfoot 60 Brushless DC Motor
1 red rod
4 yellow rods
12 white rods
16 green rods
2 grey clips
4 orange clips
4 white circle connectors
12 red connectors
4 purple sliding connectors
4 blue sliding connectors
Step 2: The Mount Parts
Build parts shown in the photo. These parts will make up the motor mount.
Step 3: Mount Assembly
To assemble the motor mount. place orange connectors so that the pegs lock in the mounting holes of the motor and slide the square part of the mount on the white sticks.
Then clip the last part onto the ends of the white sticks. The motor is now secured to the k'nex mount! now the motor can be mounted on a k'nex structure.
Step 4: The Adaptor Parts
Build the parts for the k'nex adapter.
UPDATE: I found that adding two white connector to the very end of the red rod greatly helps keep the rod straight and reduces vibrations.
Step 5: Assembling and Attaching the Adaptor
Clip the yellow rods inside the red connectors on both parts and slide to one side.
Slide the assembled unit over the shaft of the motor ensuring that the yellow rods fit inside the groves of the prop adapter mount. Then screw the washer and nose cap on the motor shaft to secure the knex on the motor.
Once the k'nex is secured to the motor clip the white connectors of the final part to the ends of the yellow rods.
Update: I found that the nose cap had a tenancy to unscrew, my solution for this was to use zip-ties to prevent it from unscrewing.
And thats it! You can now control k'nex contraptions using a brushless DC motor! Be sure to check out my other Instructables!
If you post an instructable which uses something from one of my instructables, let me know, I'll post a link to your 'ible in my applicable 'ible.
  • Minecraft Challenge 2018
  • Paper Contest 2018
    Paper Contest 2018
6 Comments
This is exactly what I was looking for... You always need a lot of power when doing some big stuff...
I had to use double 6v knex motors for each track of my tank to get enough power.
Using brushless motors also gives you countless options when picking ESC. There was only one (just 1) ESC option for brushed motors that can also do reverse...
Glad you like it! Just to let you know, have not tested it yet as i do not have a proper ESC for it. I'll try to post a video of it in action once I get it running.
Looks really cool :D what does it do? XD
The motor is designed for use in RC airplanes. This mount and adapter allows us to use it with knex.
Reasons for using this instead of knex motors:
Higher torque (probably too much for the knex to handle) :P
Higher RPM than knex motors.
Variable speed. Speed is controlled through an electronic speed controller which can be controlled with an Arduino/microcontroller or a RX reciever.
Oh okay thanks for your help :D now I understand it seems even cooler ;)
Awesome!
