Knex CCB1 (Compact Combat Bow 1)
488
19
Published
Introduction: Knex CCB1 (Compact Combat Bow 1)
This is my first crossbow on instructables. I had made one before this that was almost as powerful but. this thing was too beast for it. Enjoy the pictures.
    • Casting Contest
      Casting Contest
    • Stick It! Contest
      Stick It! Contest
    • Planter Challenge
      Planter Challenge
    19 Comments
    It might be old, but it's insanely powerful
    True. Crossbows usually are. When I'm done with my D-bow v2 I'm going to post showing the gun off. It will use a rail pin system to prevent the firing pin from exploding, and will use a more complicated trigger mechanism than of the first bow I posted. If it works right, it will also be insanely powerful, maybe even more insanely powerful than most insanely powerful guns. :)
    Mine doesn't have a pin though so it cant explode
    Yeah, but you have to keep in mind. My gun is using a Logic bow mech. That means it's a pin gun powered by a ratchet slingshot, or a hybrid k'nex gun if you prefer simpler terms. Plus, as an added bonus ratchets are so freaking strong they can easily hold back more than 20 bands. I think I just went overkill with power. XD
    Thanks. I forgot to mention it also uses a concept from oblivitus that allows front barrel mechs built for it to be removed and interchanged. If you noticed my first D-bow being assembled with just metallic silver rods, it uses the same concept. For example, you have a TR-18, a shotgun shell, and a NAR barrel mech. These can be removed from the front of the gun and be swapped out, turning 1 gun into 3 different types of guns without just building all 3 guns as a whole. This is a truly innovative concept that saves on parts. If I can REALLY get the v2 to actually work, it would be so epic it would even out perform most railguns. And that would be a huge step towards making adaptive weapons possbly the future of k'nex gunning.
    OMG, this looks like my modified overkill.....
    but with a better stock
    oh, and i modified my removing the turret, it didnt work for me.
    i like the look of it alot! good job =D
    Distance: 2 strings:35yrds-40yrds or 105ft-120ft
    3 strings:55yrds-60yrds or 165ft-180ft
    (String)-2 rubber bands tied together
    It can now shoot through 3 cans
    i like it
    This looks great =D And I can see its power =D
