Knex Circle Ball machine
 by I_am_Canadian
Well, here is a small ball machine, with a twist - No lift!
What?! No lift? How the heck does that work?
Well, it works like this. The track is a smooth flat circle, sitting on the base. The base has four "Arms" that stick out, and at the end of each one is a mechanism that makes a rod go up and down. These uppy-downy rods connect to the circular track and cause it to ossilate in such a way that the ball rolls around in a circle. Watch the video to make sense of it all.
Hope you like it!
Step 1: Piece list
Here's the piece list.
Rods
Green - 180
White - 64
Blue - 162
Yellow - 80
Red - 12
Connectors
Dark Grey - 4
Light Grey - 16
Red - 40
Green - 8
Yellow - 144
White - 12
Orange - 9
Purple - 137
Blue - 20
Other
Tan Clip - 10
Silver Spacer - 72
Blue Spacer - 38
Hinges - 4
Ball Socket - 1
Ball Joint - 1
Red Gear - 4
Yellow Gear (large) - 2
Blue Gear (tiny) - 1
One motor
Got those? Lets get cracking.
Step 2: Track
This is the track. Whoopee!
1: Make the... track. It has 48 Yellow connectors on the inside and 48 on the outside. The inner track is solid, but the outside is not connected. Its made of yellows + Green rods. See the following two photos to see what I mean.
2: ---
3: ---
4: Make this
5: Make four of these.
6: Make four of these too
7: Put the first four on like so
8: And the other four on like so
9: Put the track in like so. Its connected to the frame every 6th piece.
10: Close up of what the connections look like.
:-D
Step 3: Base Arms
These are the arms that go out from the base. Make them. NOW!
1: Make these two bits
2: Put it together
3: Make these parts
4: Make this. Be sure you get all the spacers in the right spots
5: Close up of one end
6: Close up of the other end
7: Build this
8: Make this too
9: Put thems together
10: Add that axle thing. Presto!
11: Close up of the end
12: Put that one bit on top
13: Add the yellow rod/hinge connection
14: Close up
15: Add on the rest of the frame like so
16: Make four! Leave out one yellow rod on top of one of them. See note.
Three cheers for you.
Step 4: Base Center
This is the little bit where all the gear awesomeness happens.
1: Make these these three bits and get the spacers ready
2: Put the geared rod through the motor hole, and the other two as seen. Put spacers on.
3: Other side
4: Make this guy
5: Another side
6: And another view
7: Make four! (ouch!)
8: Build this
9: Make This gear assembley from this and the next two photos
10: ---
11: ---
12: Make this
13: Build these four corners
14: Build these three
15: Build this
No, this is not the last step. Keep going.
Step 5: Assembley
1: Put one of the corner pieces on it
2: Add one of the other pieces and put on another corner
3: Same again...
4: And once more
5: Add that center bit
6: Add in a gear bit into all four openings
7: What it should look like now
8: Add the yellow gears with the teeth facing down
9: Put that piece on top now.
10: Add motor thingy on like so. Sorry I didt't get any better shots of the connection.
Booyah!
Step 6: Allignment
Alignment? What the heck?
Well, the way it works out, the gears dont exactly line up at the moment. Its hard to explain. Just do as I say.
1: Turn on your motor untill one of the shafts is like so
2: Take your next shaft. Lightly, lift the yellow gears up so that you can turn the one shaft while the others stay stationary. Make it so that it is 90 degrees farther in rotation than the previous shaft.
3: It will look like this then
4: The next one will be like this, and the last one will be pointing down. You may want to double-check that they are all alligned.
That was confusing, hopefully you did it right, though. Your all done now!
Step 7: Done!
Horay! You are now able to waste away hours of your life staring at a ball rolling in a circle.
Thanks!
-I_am_Canadian
1-40 of 183Next »
www139 says: Feb 16, 2013. 4:34 AM
oh my!!!!
talk about enginering!!!
JonnyBGood says: Sep 13, 2012. 3:28 PM
Awesome machine! Are you a hypnotist by chance? because this thing is very amusing and hard not to watch. I modified mine with second track on top of the first one for even more fun.
I_am_Canadian (author) in reply to JonnyBGoodSep 14, 2012. 7:18 AM
Thanks, and that sounds awesome! Do you have a photo?
JonnyBGood in reply to I_am_CanadianSep 14, 2012. 9:04 AM
Yep. Just took it hopefully it's visible through my mess!
I_am_Canadian (author) in reply to JonnyBGoodSep 16, 2012. 1:35 PM
Thats awesome!! It would be so sweet to have like 20 stacked on each other :-p
Thanks so much for the photo!
JonnyBGood in reply to I_am_CanadianSep 16, 2012. 4:33 PM
Twenty would be cool if I had enough knex. I might manage 3 at most. =) No problem I love using my camera.
viniciusmacedo says: Jul 29, 2012. 1:11 PM
It looks wonderful, but it doesn't work properly...
I_am_Canadian (author) in reply to viniciusmacedoAug 11, 2012. 2:25 PM
Could I help you troubleshoot?
KGuy says: Jul 5, 2012. 10:18 AM
Great job!!!! I might modify-changing the motor pack with a standard one (mine broke).
I_am_Canadian (author) in reply to KGuyJul 14, 2012. 1:50 PM
Nice, well done! Thanks for building!
natebman says: Jun 13, 2012. 11:16 AM
just got done building it and i have to say it is awesome. modified mine a little to run with a hand crank instead of a motor, but thnks for the great build
I_am_Canadian (author) in reply to natebmanJun 14, 2012. 11:18 AM
Sweet, thank you so much! I'd really love to see the crank you made, do you have any photos?
Thanks again!
natebman in reply to I_am_CanadianJun 21, 2012. 8:40 PM
here is the picture of the crank and the picture of my completed ball machine
I_am_Canadian (author) in reply to natebmanJun 23, 2012. 8:19 PM
Man, that looks fantastic! I really like the rails you added. Very impressive!
instructables is cool says: Jan 17, 2012. 1:02 PM
[Removed by the FBI]
Just kidding! IT'S AWESOME!!!
KNEX-pert says: Dec 25, 2011. 4:49 PM
Amazing! It's amazing how you were able to make it function that way. Great job!
I_am_Canadian (author) in reply to KNEX-pertDec 27, 2011. 7:43 AM
Thank you!
KNEX-pert in reply to I_am_CanadianDec 27, 2011. 6:26 PM
You're welcome!
Zeethesquirrel says: Oct 2, 2011. 11:09 AM
Excellent job I built it in sometime from 1-3 hours Its really cool and kinda relaxing actually REALLY relaxing I really don't know why.
I_am_Canadian (author) in reply to ZeethesquirrelOct 2, 2011. 11:31 AM
Awesome! Thanks very much!
jimopertrat says: Jul 7, 2011. 12:31 PM
i built it!!!=) so cool!
I_am_Canadian (author) in reply to jimopertratJul 16, 2011. 8:37 PM
Right on! Thanks!
mdman10 says: Jul 16, 2011. 2:40 PM
u know, for the track u could just use the already built tracks and put them in a circle. thats what im doing because i donnt have enough knex.
I_am_Canadian (author) in reply to mdman10Jul 16, 2011. 8:20 PM
Go for it! I'm sure there are alternatives.
mdman10 says: Jul 16, 2011. 2:43 PM
o it might be too small
jake scythe says: May 20, 2011. 1:41 PM
sorry a lot not a loud
I_am_Canadian (author) in reply to jake scytheMay 23, 2011. 8:11 PM
How so?
jake scythe in reply to I_am_CanadianJun 6, 2011. 5:05 PM
the strucure could be a bit diffrent but keep stability and the engine could be not as complex
I_am_Canadian (author) in reply to jake scytheJun 6, 2011. 8:08 PM
I'd be very impressed if you could simplify the motor, and any reduction of the structure would start to detrimentally affect its stability.
In my opinion.
bjarne96 says: May 26, 2011. 10:25 PM
the yellow bar that goes up and down that you can replace a red bar.
I_am_Canadian (author) in reply to bjarne96May 27, 2011. 8:21 PM
No you can't, sorry.
Jesus. says: Aug 13, 2009. 1:37 PM
i....................need..............................yellow.....................................gears!!!!!!!!!
I_am_Canadian (author) in reply to Jesus.Aug 16, 2009. 7:35 PM
You can buy them off K'nex.com relatively cheaply.
Jesus. in reply to I_am_CanadianFeb 13, 2010. 11:14 AM
Sorry for the late reply. Yeah I know, But I'm saving my money.
I_am_Canadian (author) in reply to Jesus.Feb 13, 2010. 1:16 PM
You only need to spend 5 bucks, that shouldn't take long :-p
Jesus. in reply to I_am_CanadianFeb 14, 2010. 11:29 AM
No I frased it wrong, I'm saving my money for somthing else.
dnmonsen in reply to Jesus.Jun 19, 2010. 7:04 PM
for what
Jesus. in reply to dnmonsenJul 3, 2010. 12:17 PM
I think I was saving for my computer then.
bjarne96 in reply to Jesus.May 26, 2011. 10:18 PM
on ebay.com have you knex and the yellow gear
could be a loud simpler
1-40 of 183Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
