K'nex Crossbow
1,030
Published
Introduction: K'nex Crossbow
To create this diabolical monstrosity, you will need:
25 yellow connectors
6 red connectors
32 small green rods
1 blue rod
15 white rods
1 gray rod
3 yellow rods
1+ rubber band
1 orange connector
2 white connectors
10 gray horseshoe connectors
Step 1: Main Frame
The frame is made of 7 of these three-connector units.
Step 2: Handle/Grip
Step 3: The Cross of the Bow
First take the last unit of the frame and attach a yellow rod to the middle connector.  Then add the white snowflake connectors on either end, after which you can put on the two other yellow rods.  Wrapping the rubber band(s) around the cross is pretty simple.
Step 4: Firing
You will need the bolt (top) and pin.  The bolt slides perfectly into the channel, and the pin locks it in place.  Then draw the rubber band to the red connector.  Yank the pin to fire.
    • Flowers Challenge
      Flowers Challenge
    • Make it Move Contest
    • Microcontroller Contest
    3 Comments
    meh...
