Knex Crossbow CENTER FIRE
Introduction: Knex Crossbow CENTER FIRE
Hello instructables I'm back with my new center fire cross bow. I know you all don't care about me rambling on about how great this crossbow is so ill get to the stats. But I'm going to talk about it anyway :) the main reason I built this is because there is not many light weight long range and half way accurate crossbows out there. I have built a couple crossbows on the site and all were ridiculously heavy so my main goal was make it light. It weights 1.6 pounds. Here's some stats.
Long range (200+ feet with fin ammo and a tail wind, or 100 feet in regular conditions and regular ammo)
Features acu ammo which gets shorter range but higher accuracy
Looks epic
Half way accurate (can it a can 50 feet away easily)
Strong limbs
Slick look
Slow reload time
Did I do better on my pictures? Please leave me some feedback, your feedback helps me build better guns.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Why would you say that to it center fire? Do you have a clue what that is? Rifles are center fire because of where thi pin hits the primer at the rear end of the shell, why do you kennects builders bullshit so much?
    I know what a center fire rifle is, in fact I own 5 of them. I own a Remington 700 30-06, a browning a bolt 308, a browning lever action 7mm-08, a Henery 44mag lever action, and a savage 243. All center fire. Secondly I know this thing is not a center fire, just thought it sounded cool. And third of all it is called Knex not kennects, I thought that if you had such a problem with the title you could at least spell it right you dumbass. And my final statement I probably know a whole lot more about center fire rifles than you ever will so shut up and quit pissing off knexers.
    You just go to my profile and go right above this crossbow and it will say center fire cross bow instructions, then you break out ur Knex and get building
    Really cool have you seen some of the crossbows I've made ,their not really as good as your but you have seen my compound bow I made and Mabey I can help you bye showin you how you could Mabey put the cam system on your crossbows if you want
    Na it's cool man the reason I don't have cams is I used bending limbs and this system gets more range than it would if you put cams on it. I will definitely use cams on feuture projects though! Thanks for your feedback:)
    This is really amazing. It makes me wanna build a bow...I haven't built one yet, and I think it would be pretty fun. Overall though, I'm sorry to say that I think you should post the range of a regular everyday shot, that you could go outside and shoot right now. Otherwise, when people build it, they'll complain and accuse you of lying. From reading previous comments, I understand you shot with finned ammo and with the wind. Other people might not do that, and I think that you should post that it gets a little under 100 ft with regular ammo. If you want to, you can add that it gets 200+ with finned ammo. Sorry idf I seem rude, but this is merely my input. Nice bow!
    Ok great, you might have to change the stock to your liking. The only thing I would want you to give a shot at is, make the barrel more sturdy, it can bend a bit. I could not find a solution for this. My main goal was make it light so strength got put on the back burner. I will try and get instructions up in about a week! Yay nobody has Ever wanted to build my guns.
    Haha I don't see why people wouldn't want to build them. They're all pretty good. Yeah I'll try and see what I can do about the barrel and stock. Can't wait for the instructions. :)
    Ok I will try and change it and put 100 ft but 200 ft in good condition and fin ammo. Would you build this if I posted instructions?
