Introduction: K'nex Cubic Cube
Picture of K'nex Cubic Cube
Welcome to the World of K'nex, a colorful construction toy. Here we will make three cubes inside each other, spinning in different directions, held by two rods and working with twenty gears. When built you can spin the boxes in any directions, and you can spin one, two or three boxes at once.
* Pieces are considered pieces themselves.
* Parts are considered pieces connected to each other.
* While building it helps to also click on the images to enlarge them.
* Click on the images if you would like a count of the current required pieces.
! Don't let anyone choke on any of these small pieces. !
Step 1: Set-Up
Picture of Set-Up
Pieces
Gear - (Wheels)
  • 4 Big Yellow
  • 7 Medium Yellow
  • 5 Medium Red
  • 2 Small Pin Brown
  • 2 Small Pin Light Blue
Connectors - (ID Color)(Most to Least Sides)
  • 19 White - 8 Sides
  • 15 Blue - 7 1/2 Sides
  • 12 Yellow - 5 Sides
  • 139 Purple - 4 1/2 Sides
  • 14 Red - 3 Sides
  • 14 Orange/White/Gray - 2 Sides
  • 25 Sandy - 1 Side Pin
  • 15 Gray - 1 Side
  • 14 Shiny Blue - 1 Side Non-pins
  • 8 Orange - 1 Side Push-ins
Rods - (Sticks) (Shortest to Longest)
  • 8 Green
  • 22 White
  • 80 Blue
  • 27 Yellow
  • 94 Red
  • 42 Gray/Orange
Other Types - (Panels & Spacers)
  • 4 Medium Square Panels - Orange/Blue/Black/Silver
  • 41 Silver Tubings/Spacers
  • 31 Blue Tubings/Spacers
Step 2: The Stand Bottom
Picture of The Stand Bottom
Make the 10 shown parts and connect six with red and orange rods like shown.
Step 3: The Stand Top
Picture of The Stand Top
Built the next two shown pieces and connect them to the last four parts left from step one using more red and orange rods.
Step 4: The Stands Connection
Picture of The Stands Connection
Connect the top and bottom parts together like in the image.
Step 5: Box 1 Structure
Picture of Box 1 Structure
Find all the required pieces and make the structure shown in the image.
Step 6: Box 1 Middle
Picture of Box 1 Middle
Take the panel with two pieces and the 21-pieces part and add the such shown pieces.
Step 7: Box 1 Panels
Picture of Box 1 Panels
Put the two structure parts together and then put on the panels.
*Make sure the sandy pins (on the tips) are inside and the yellow rod points out.
Step 8: Box 2 Structure Basic
Picture of Box 2 Structure Basic
Make 20 purple doubles.
Using those, make the starting of Box 2 with blue rods and white connectors.
Step 9: Box 2 Bits
Picture of Box 2 Bits
Make the bits as they are shown and prepare them for the next step.
Step 10: Box 1-2
Picture of Box 1-2
Take some of the box bits and build them the way they are shown.
Then put Box 1 into Box 2.
* Tighten pieces like the sandy pin connectors on the yellow rod in the directions that they are shown.
Step 11: Box 2 Red Gear
Picture of Box 2 Red Gear
Connect the new blue and yellow rods.
Take the red gear/wheel on the red rod with two blue spacers and two sandy pin connectors.
Poke the short tip through the center of the chosen white connector and lock it on with the second sandy connector.
Step 12: Box 2 Brown Gear
Picture of Box 2 Brown Gear
Take the two bits containing the tiny brown gears and clip them by their side red connectors and orange connectors.
Step 13: Box 2 Yellow Gear
Picture of Box 2 Yellow Gear
Clip on the other two bits and red rod along with the yellow gear.
Step 14: Box 3 Thin Stars
Picture of Box 3 Thin Stars
Make the next eight stars shown as three types.
Step 15: Box 3 Bottom Structure
Picture of Box 3 Bottom Structure
Build the bottom edges and connect on the three chosen stars.
Step 16: Box 3 Tightening
Picture of Box 3 Tightening
Take and clip on four shiny blue connectors. Build and add the two small bits.
Step 17: Box 3 Sides
Picture of Box 3 Sides
Build the four new bits and with also four stars connect them with the edges part.
Step 18: Box 3 Edge Tightenings
Picture of Box 3 Edge Tightenings
Take the shown pieces and clip them on and set the other few for the next step.
Step 19: Box 3 Brown Gear
Picture of Box 3 Brown Gear
Step 20: Box 3 Red Gear
Picture of Box 3 Red Gear
Step 21: Box 3 Yellow Gear
Picture of Box 3 Yellow Gear
Step 22: Box 3 Gear Edges
Picture of Box 3 Gear Edges
Step 23: Box 2-3 Assembly
Picture of Box 2-3 Assembly
Step 24: Box 3 Giant Gear
Picture of Box 3 Giant Gear
Step 25: Box 3 Strength
Picture of Box 3 Strength
Step 26: Box 3 Giant Gear B
Picture of Box 3 Giant Gear B
Make the gear rods and take the rod B to start.
Step 27: Box 3 Giant Gear A
Picture of Box 3 Giant Gear A
Take rod A and build it like the last step.
Step 28: Box 3 Lid
Picture of Box 3 Lid
Build the lid and add it on.
Step 29: Assembly
Picture of Assembly
Build the spinning parts and then we start to put all parts together.
! Hold up the Box as you assemble... till the last step.
Step 30: Rod Assembly
Picture of Rod Assembly
Assemble onto the rods as shown.
Step 31: Last Step
Picture of Last Step
Hooray!
No more steps.
You are done!
sandroknexmaster (author)2015-12-15
That's cool!
Lexi Knex (author)2015-12-03
i will build it but before how does it work ??
Knexstructable (author)Lexi Knex2015-12-03
Spinning the Spinning Parts (built in step 29-31) you can control the cubes and which to spin and their speed.
Linkin_J_Knex (author)2015-12-02
this is really interesting and cool! I wonder if somehow it could be integrated into ball machines 0_o
DIY Hacks and How Tos (author)2015-12-02
This is one of the more interesting knex projects that I have seen.
I made the manual itself as part of a college project.
About This Instructable
366views
2favorites
License:
More by Knexstructable:K'nex Cubic CubeK'nex Box of Gravity
Add instructable to:
