Introduction: K'nex Differential (Version 2)
Picture of K'nex Differential (Version 2)
Car differencial built from k'nex for k'nex vehicle by Forsterimages. Here is what your finnished diff. will look like. Also see version one.
Step 1: Parts Required
Here is a list of the parts you will need:
2 white connecters,
2 brown cog wheels,
2 grey cog wheels,
4 orange connecters,
4 yellow rods,
4 white rods,
8 silver spacers,
21 blue spacers,
12 black connecters,
1 yellow cog wheel,
some blue tack.
Step 2: Step One
Picture of Step One
Take the white connecters and attach four black connecters.
Step 3: Step Two
Picture of Step Two
Take two of the yellow rods and attach a grey cog wheel and a blue spacer to each.
Step 4: Step Three
Picture of Step Three
Take the navy rod rod and attach the two brown cog wheels to each end placing a grey spacer between them. Then place a blue spacer on each end and then some blue tack.
Step 5:
Picture of
Take two of the orange connecters and and attach them to both ends of the part made in step three.
Step 6: Step Five
Picture of Step Five
Take the parts made in steps one and two and place the yellow rod through the middle of the white connecter. Do this twice.
Step 7: Step Six
Picture of Step Six
Take two red connecters and four black coonecters and attach them as shown. Do this twice.
Step 8: Step Seven
Picture of Step Seven
Take the part made in step four, four white rods and eight blue spacers, and attach them as shown.
Step 9: Step Eight
Picture of Step Eight
Take the parts made in steps five and six and a yellow rod and attach them as shown.
Step 10: Step Nine
Picture of Step Nine
Take the parts made in steps eight and seven and attach them as shown. Leave one grey and one blue spacer for the next step.
Step 11: Step Ten
Picture of Step Ten
Take the part made in step nine and place the yellow cog wheel over one of the yellow rods. Attach it to the nearest white connecter using a piece of wire.
ahmetasc1 (author)2015-03-15
i made it but one wheel is always strongest other one.
dommy (author)2010-08-03
where would u put the axel???
David97 (author)dommy2011-11-26
The whells go on the yellow rods then it is driven from the yellow gear.
adam8949 (author)2011-03-20
I found a way of holding the yellow gear on without the wire but it does require a broken rod.
Speed8ump (author)2010-01-29
 I posted something very similar a while ago (here: www.instructables.com/community/Knex-differential/ ).  Instead of using wire I modified (drilled a hole in) the yellow gear.  Your cage requires more pieces, but the additional structure may make it sturdier, I'd have to build one to find out.
MarijnS95 (author)2009-06-22
I've maked and it works really good. i m making a car with it and also the steer system from king1000.
Forsterimages (author)MarijnS952009-06-22
I'm glad you like it! Also see version 1.
Hey whats the diffrence between them does no. 1 hold more weight?
I made no.1 first, then a while later made no.2, which i slightly more compact.
wehe-tehe (author)2009-08-14
cool 5*s
neilhorse (author)2009-07-06
What is the piece of wire for?
MarijnS95 (author)2009-06-21
looks cool, i'm going to make it
arrow shot (author)2009-06-21
looks like some cimplicated part you got there :o
About This Instructable
6,280views
10favorites
License:
More by Forsterimages:K'nex Differential (Version 2)K'Nex Differencial (Version 1)
Add instructable to:
