Knex Eater Automaton
Introduction: Knex Eater Automaton
This is my latest automaton. It picks up knex balls and eats them.
It has two moving arms, a head that turns, and a mouth that opens.
If you're making this, make sure you have at least 4 ball joints, 2 ball sockets, 2 hinges, and 4 pulleys.
Step 1: Base
This is the base of the automaton.
Step 2: Scaffold
This part will hold the motor.
Step 3: Motor and Crankshaft
I'd recommend using the motor where the battery pack is separate from the motor.
Step 4: Adding Motor and Crankshaft
This is how the motor connects to the scaffold.
Step 5: Bearings
These wheels will help keep the head on straight.
Step 6: Neck
This is the main axle. It will turn back and forth.
Step 7: Adding the Neck
This part fits in the middle of the bearings.
Step 8: Spine
These are all the parts that will go on the main axle.
Step 9: Adding the Spine.
Pay careful attention to the direction of each part on the spine.
Red connectors are used because they make the right arm go further than the left arm. This is needed because the crankshaft makes the left arm go further than the right arm.
Step 10: Adding the Base
The spine will go through the white connector in the base.
Step 11: Arms and Shoulders
Step 12: Adding the Arms
The Shoulders are connected to the Scaffold, and the Arms are connected to the Spine.
Step 13: Head
Most of this step can be replaced later.
Step 14: Finished!
Add the Head to the Neck, and attach the back of the head to the scaffold.
Now you're done! Turn on the motor to make sure nothing is jamming. If it is, go back to step 9 (adding the spine) and make sure everything is pointing the right way.
Step 15: Entrance and Exit Tracks
This is an example of an entrance and exit track. I'd suggest making your own. When you design your ball machine, try to avoid the need for the scaffold in this step.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    This this is awesome!! I would love to see it in a ball machine
    Yeah, this is really nice and totally deserves the Feature!
    The simplicity of the mechanism combined with how well it works, shows that you´re a great builder. Love it!
    Amazing! Congradulations on the feature too! :D
    Haven't heard from you in a while... Beautiful creation!
    Keep it up, man! Good Job!
