Hi this is my first actual gun.
the name stands for:
Flash
One
Shot
Compact
Rifle.
this is a very good good and I had fun building it and hope you do too.
Pro's:
Compact.
Sturdy.
True trigger.
Foregrip.
Ramrod NEVER comes out of barrel.
Accurate. (With yellow rods)
Good range. (with my rubber bands I got about 40-45ft)
Cons:
No magazine.
Stock is too big.
Enough! Lets start building
Step 1: Stock
The other side is ecsacly the same. Also remember the blue rods.
mford lee says: Apr 14, 2011. 12:12 PM
awsome gun 4.9*
Tom Buckey (author) in reply to mford leeApr 19, 2011. 11:17 AM
Thanks!
Knexman15 says: Apr 15, 2011. 5:42 PM
making it now looks good
slimshaddy says: Mar 20, 2011. 8:02 AM
4.5* and this gun was posted on my birthday
Tom Buckey (author) in reply to slimshaddyApr 7, 2011. 6:26 AM
Thanks! And happy Birthday for then!
slimshaddy in reply to Tom BuckeyApr 7, 2011. 7:43 AM
thanks
TigerNod says: Jan 23, 2010. 10:50 AM
Weird, I thought I subbed to you a long time ago. Anyways, good job, 3.5 stars.
Tom Buckey (author) in reply to TigerNodJan 24, 2010. 10:11 AM
Thanks.
TigerNod says: Jan 23, 2010. 10:54 AM
"Picture 2-3: yes that is a broken yellow rod."
Correction: that is a yellow connenctor.
Seleziona says: Dec 26, 2009. 4:27 PM
I can't imagine this being strong at all. :(
DJ Radio says: Oct 3, 2009. 12:32 PM
It looks weak. Try to use a black rod as a ram and make a longer barrel. 2 connectors between trigger and bullet lock does not make for a powerful gun. There have been single shots that shoot around 70 feet and require no modded parts.
Tom Buckey (author) in reply to DJ RadioOct 3, 2009. 3:23 PM
Well the modded part does not make any difference to the range. Thanks for the advice I'll be sure to do that in my next gun.
DJ Radio in reply to Tom BuckeyOct 3, 2009. 3:42 PM
Where did I say anything about modded parts? The short traveling distance of the firing pin makes the gun weaker.
Tom Buckey (author) in reply to DJ RadioOct 4, 2009. 10:55 AM
"There have been single shots that shoot around 70 feet and require no modded parts." There is where you said about the modded parts. Ill be sure to make the ramrod a black rod too.
DJ Radio in reply to Tom BuckeyOct 4, 2009. 11:41 AM
Yeah, but that wasn't related to my first statement, the reason your gun is weak isn't because of modded parts, it's because of the short traveling distance of your ram. Oh and make the barrel longer, more connectors between the trigger and bullet lock mean more acceleration speed.
Tom Buckey (author) in reply to DJ RadioOct 4, 2009. 12:14 PM
Okay, thanks for the advice! I'm worling on a pistol for now!
Killer~SafeCracker says: Oct 1, 2009. 2:37 PM
If you know the stock is to big then why didn't you fix it??
DJ Radio in reply to Killer~SafeCrackerOct 3, 2009. 12:41 PM
It could be used as a cheekrest.
Killer~SafeCracker in reply to DJ RadioOct 3, 2009. 5:47 PM
Could, but for one it would not feel good.
Tom Buckey (author) in reply to Killer~SafeCrackerOct 2, 2009. 8:38 AM
Because I did make it smaller but took away the overall look of the gun. In other works it didn't look as good.
Hiyadudez in reply to Killer~SafeCrackerOct 2, 2009. 3:11 AM
Seconded.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
