Introduction: K'nex F.O.S.C.R
About: Hi! Im tombuckey. I live in Liverpool, England. I build knex ball machines from my own ideas and also build other peoples knex guns. I have a Youtube account just type in Tombuckey in the search bar and all m…
Hi this is my first actual gun.
the name stands for:
Flash
One
Shot
Compact
Rifle.
this is a very good good and I had fun building it and hope you do too.
Pro's:
Compact.
Sturdy.
True trigger.
Foregrip.
Ramrod NEVER comes out of barrel.
Accurate. (With yellow rods)
Good range. (with my rubber bands I got about 40-45ft)
Cons:
No magazine.
Stock is too big.
Enough! Lets start building
Step 1: Stock
The other side is ecsacly the same. Also remember the blue rods.
Step 2: Firing Pin Holder.
This section ataces the stock to the main body. It also houses the firing pin. Be carefal because I show both sides of the housing. Ask for help if you need it.
PLEASE LOOK AT BOTH PICTURES
Step 3: Handle
Pritty easy but only add rods where shown. Do NOT add them if the are not shown.
Step 4: Barrel
You shouldn't need help.
those blue connectors can be replaced by the tan connectors.
Step 5: Main Body
Be sure to read the image notes.
Picture 2-3: yes that is a broken yellow rod. I diddnt break this on purpose it was already broken from a previuos gun. If you dont want to break your connector you can use a orange connector.
Step 6: Trigger
This is simple. It is the trigger and trigger holder
Step 7: Foregrip
pritty simple. add a elastic band at the bottom.
Step 8: Firing Pin
Simple.
Step 9: Stock to Holdor
Give a general description of the Stepthe connection points
Step 10: Barrel to Main Body
Simple but remember I show both side and make sure you have the barrel the right way round.
Read the image notes.
Step 11: Trigger & Foregrip
Please read the image notes.
Sorry for the blury picture.
Step 12: Trigger and Overall Connection
you shouldnt really have any problems..
Step 13: Adding the Ramrod
Step 14: Sights and What-not
You should know where to put the bands. I use 3 bands to get about 40ft.
