Introduction: Knex FX-9 Pistol V1.2
Here it is my new, long awaited, (not really) FX-9 Pistol. I know that it is smaller than my other guns but I had to start somewhere. This is my favorite pistol I have made. It has a good range, Hidden storage, and a safety . Now I now that there is really no use for it but the point of it is to make the gun more realistic. I will be making a version 1.3 later. Be sure to watch the video. It shows the secret storage, safety, and how it shoots.
Here are the facts:
Has a 7 round handle fed mag
Has a hidden storage for a sniper round.
Has a good range
Has safety
It is very comfortable
Does it sound good?? Let's start.
Step 1: Part Count
It's terrible when you are almost done with a gun and don't have enough parts. So I added a piece count.
Connectors:
White 12
Yellow 12
Green 8
Red 7
Light Gray 2
Orange 15 ( one needs to have one tab cut off) if you don't the gun will jam more.
Rods:
Black / Gray 1
Yellow 1
Blue 9
White 15
Green 55
Clips:
Gray 13
Blue 4
Tan 10
Odds & Ends:
Ball Joints 5 ( all can be replaced one is on the firing pin and can be a orange connector and the rest can be gray clips. But you will need a rubber band.
Black Hands 16
Rubber bands
Step 2: Ammo Storage
This is going to be the hidden storage.
Pic 1: build 2
Pic 2: build
Pic 3: add white rods
Pic 4: slide over the white rods
Pic 5: add second side
Pic 6: add a black hand to a hinge
Pic 7: add white rod
Pic 8: add hinge
That wasn't that hard
Lets go to the next step
Step 3: Handle
Here is the handle.
Pic 1: build 2 of each
Pic 2: build both. Here is where that cut piece comes it play.
Pic 4: add both sides
Pic 5: add the other panels
Pic 6: slant and add black hands
Pic 7: build both
Pic 8: build both
Pic 9: add on each side of the handle
Pic 10: add green connectors
Onto the barrel.
Step 4: Barrel
Okay here are the parts for the barrel
Pic 1: Build both
Pic 2: Build
Pic 3: Build
Pic 4: Build both
Step 5: Check
Okay this is what you should have built.
Step 6: Construct the Barrel
Okay I hope this is not going to be too hard.
Pic 1: build both
Pic 2: add blue rods
Pic 3: add these diffrent parts (don't forget the spacers)
Pic 4: add the second side
Pic 5: add blue rods on the handle
Pic 6: now add the barrel to the handle
Pic 7: now add the third and forth side panels
Great now you are almost done.
Step 7: Put It All Together
We are almost there.
Pic 1: Add the rails
Pic 2: Add the flip top
Pic 3: Build the trigger
Pic 4: add trigger and gray clip.
Pic 5: build both
Pic 6: add ram and rubber bands like so
Pic 7: add tan clips to the blue rods if you want
Step 8: Loading and Firing
Pic 1: Load bullets into the mag like so
Pic 2: add mag pusher and rubber band
Now when you are ready to use slide the orange connector back pull the ram back and pull the trigger.
Credit goes to Trauts for the basic handle design.
Have fun. watch the video. Rate and comment.
