K'nex Giant Ferris Wheel
15,527
24
46
Posted in PlayKnex
Introduction: K'nex Giant Ferris Wheel
This is my first Instructable. It's for a 234 cm(7,68 ft, 92,1 in) tall K'nex Ferris Wheel.
I often had problems with K'nex ferris wheels, because it's hard to keep the towers strong, when they are only connected with one black rod.
This ferris wheel has an open hub, so there is room to connect both towers by a strong bridge.
Step 1: Building the Base
First you have to build the base which holds both support towers, the 12V engine, and the first reduction gears. It also forms the boarding platform. It looks really small for the size of the wheel, but it did a good job on mine. When you take it outside, it might be an idea to add further support. For indoors, this is good enough.
Step 2: Building Support Tower 1
Next is support tower 1 It's a fairly simple red rod tower. It also has the drive shaft attached to it, which drives the wheel.
Step 3: Support Tower 2
Support tower 2 is built up of yellow rods. On the bottom end there is a red rod block, which is attached to the base. It's important to make the connection between the red block and the yellow tower quite strong, if you don't, the tower might break there.
It's important to put a gray connector on one of the vertical rods on the top block. This will be connected to the bridge between the towers.
Step 4: Top of Tower 1
The top of tower 1 has the final drive on it, which makes the connection between the vertical drive shaft and the chain drive.
The bridge which runs through the hub, from tower 2 is also attached to this part.
It also supports one side of the drive/support shafts.
Step 5: Top of Tower 2
The top of tower 2 is quite simple, it doesn't have any gears in it. It supports the drive/support shafts, and it has the bridge on it.
Step 6: Drive/support Shafts
These shafts hold the weight of the wheel itself, and also drive the wheel via 2 chain drives. It's important to fill the rods completely with rings, wheels and connectors. If not, there may be too much room at the bearings, so the shafts may fall out.
For the main shaft (right one, from top to bottom) the following parts go on the rod.
1 grey connector
1 ring
1 big wheel, with rubber bands around it, these add grip.
2 beige wheel holders
1 red wheel
1 red wheel
14 rings
1 beige wheel holder
1 big wheel
2 red wheels
The second shaft is the same, exept that it hasn't got the second set of red wheels. Fill up this space with rings and beige wheel holders.
Step 7: Tower Assembly
Quite simple really, build all the parts together, to form the towers, whith the drive mechanism.
Step 8: Wheel Construction
The wheel is built up out of 31 elements. The elements themselves have 3 parts, the drum part, the wheel part, and the car part.
Building the outer ring is a matter of fine tuning. I found the easiest way to do this was to attach the wheel to the tower, and testing a bit with blue and white rods.
The cars I've built are very simple, but it was all the K'nex I still had left, you can build whatever car you like.
Step 9: Final Assembly
By building the wheel in two halves, they can be mounted around the bridge/drive/support shafts. Each halve will be HUGE by now. I've tied a rope around my ceiling lamp to keep the top halve up, while connecting the bottom halve. Another possibility is to keep the top halve balanced on top of the two drive/support shafts.
I found it easy to keep the car parts(everything outside the outer ring) of until the wheel was mounted on the tower.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    46 Comments
    it is really good! where do you get all the pieces ?!?! : )
    lol. in one ferris wheel set there is a lil' orange cylinder that plays carnival music. i have one. staring at it as i type.
    I have one from a rolercoster thati think would qwork to, its motion activated to it makes the sounds of it turning and people screanming and chearing :)
    i have one too. i got it from a fair ground set
    me too, it is so annoying :D
    rig it up to someones door for some laughs
    hey cool could i do it in wood
    do you need them???
    I got those from the ball machine crane set.
    could you please tell me what those blue and yellow platform things that you used are called? and maybe what set i can get them in?
    When I build ferris wheels I always get stuck at the part where a rod has to serve as axis and carry the whole weight of the wheel. You found a nice solution to that! grats.
    hey does it use more then 2 black rods??
    Yes, it already needs two for the wheel axles. Perhaps they are replacable by grey ones, but I didn't check that.
    wauw die heb ik ook een keer gebouwd maar dan anders maar het ziet er cool uit maar die ga ik niet bouwen dus later!
    Lol, ik zit nou in een verhuizing, heb nog wel wat leuke K'nex plannetjes op stapel staan!
    i wish i had enough pieces to build this...
    Wow, I wonder how many pieces it takes.
