Introduction: Knex Grenade (Stielhandgranate)
A knex stick grenade that has a blast radius of around 3 metres depending on elastic bands. The grenade fires 8 green rods in four directions and has a handle for easy throwing. Lots of people posted knex guns so I thought I would post a grenade!!!
Step 1: Pieces
You need:
10 White connectors
4 Yellow connectors
8 Green connectors
8 Purple connectors (individual) or 4 in pairs
4 Red connectors
8 Grey connectors
16 Light Grey connectors
8 Tan connectors
4 Red/Orange rods
24 White rods
8 Blue rods
4 Green rods (excluding ammo)
16 Blue spacers
2 Square Mini Panels/ 2 White connectors+ 8Green rods
8 Rubber bands
And some flexible wire
Step 2: The Handle
Take the four red/ orange rods and connect them to the 2 white connectors like this.
Step 3: Handle-grenade Connection
Get 2 green connectors and a green rod and connect them as shown and then do it an another 3 times and connect the four parts to the panel.
Step 4: Main Frame
Take 4 White and 4 purple connectors and 16 white rods and put them together like this!
Step 5: Charges
follow picture
Step 6: Construction
connect the charges to the frame like so....
Step 7: Construction
add the top and handle like this
Step 8: Finished
Now your grenade is finished all you have to do is make the circles that explode the grenade.
Step 9: Firing Rings
Get the wire and use some pliers to snip the wire so it is around 9cm and make it in to a cirle with a diameter (width) of around 1.2cm - 1.3cm. Do this a few times as unless you tie the rings to the grenade they are very easy to lose!!!!
Step 10: Loading and Firing
Take the top and bottom off the grenade to expose the firing rods, then push all of the rods into the middle like in the 4th and 5th pictures. Then all you have to do is put the green rods in the barrels and THROW!!! The impact of the grenade hitting the floor or the wall will make the grenade explode and fire green rods everywhere!!!!
