K'nex Hand Gatling Gun by ultimatesx9
Step 8: Loading And Firing
1. pull back the trigger
2. Pull back all the Firing Pins and lock them with the white rod
3. put the yellow or gray rods into the end of the Clip
4. turn the handle anit-clockwise (depending on which way you put the motors in)
5. push the trigger back
6. twist the barrel clockwise (if it is set this way) and let go, if youre lucky you may get a good four round shot, but you will mostly get a 1 or 2 shot
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
