Knex Lowering Ball Arm Element
415
5
4
Posted
Introduction: Knex Lowering Ball Arm Element
Step 1: Pieces
Here are the pieces you will need
Wheel: 1
Tire: 1
Blue: 33
Green: 17
White: 9
Yellow: 20
Red: 11
Gray: 3
Connectors
White: 2
Red: 12
Green: 3
Light gray: 2
Dark gray: 7
Purple: 17
Blue: 5
Yellow: 15
Miscellaneous
Blue splicers: 14
Gray splicers: 23
Tan connectors: 9
Regular gear: 5
Step 2: The Gears and Lower Arm
This is definitely the hardest step of them all. If anyone needs more pictures, please tell me.
Step 3: The Frame
The easiest step of them all
Step 4: Attaching
This is another easy step. You will need two dark grey connectors
Step 5: The Lowering Arm and Weight
This is the step where the element works most
Step 6: Attaching
Yeah.... That's it
Step 7: The Frame
This holds the arm so it lowers in a certain way
Step 8: Attaching
Simple as that, make sure the red rods go through though
Step 9: The Parh
What lets the ball go on the arm
Step 10: Finsished
Finished!!!!!! Make sure to check out DISCOMBOBULATION, the winner of the knexpert contest of America!
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
4 Comments
Ok.. Sons is over and I have done my experiments.. adding weight to the counterweight does not in fact slow this thing down... it makes the first arm reset too high so that a ball will fall straight though from the top path... lesson learned... Still a great design... 8 stars for you
Just built this most excellent element.... I'm guessing that if I add more weight to the counterweight, it would operate a bit slower... I'll let you know in a minute or 3... or after the Sons of Anarchy is over.... Good job
