PIECE COUNT:
(Most counts are an approximate, I just took a quick count)
Green rods: 100
White rods: 75
Blue rods: 21 + 1 bendable
Yellow rods: 4 + 2 bendable
Red rods: 2
Gray rods: 26 + 1 black one (firing pin)
Gray connectors: 70
White connectors: 4
White "Snowflake" connectors: 27
Red connectors: 33
Green connectors: 110
Yellow connectors: 61
Blue "Snowflake" connectors: 10
Purple connectors: 4
Gray gears: 2
Tan clips: 4
Blue clips: 1
Y-shaped things: 8
Hinges: 3
U part of joint: 1
Remove these ads by
Signing UpStep 1Front handgrip
NOTES:
Picture 1: Expand this out until it is 12 long on each level, 24 long total
Picture 4: The rods don't actually fully snap into a place, however, they are wedged in there as show. Therefore, they will make a soft click if they're in place, and will slide smoothly back and forth.
Picture 5 & 8: These pictures are at opposite ends of the barrel. The orange pieces are snapped on the same way at both ends here
Picture 11: This is just a ramrod, do not add this if you plan on using a magazine system with this gun because it effectively plugs the barrel
Picture 14: The gray connectors between the white snowflake and orange connector can be cut; you can cut the tops off of them, because this is where the magwell will eventually go.
Pictures 15 &16: This is just a suggested barrel design, i was almost out of pieces so whatever i had i used for it, feel free to make a better barrel.
ORIENTATION NOTES:
Pictures 4, 5, 9, 10, 11, 12, and 13 are the FIRING END of the gun
Pictures 6 - 8 are the BODY END of the gun.
IMPOSSIBLE
All triggers block some kind of firing system, making it a block trigger.
Every kind of trigger either catches or stops something. The trigger mechanism BLOCKS a piece from moving and hitting the bullet/firing rubber bands.
When you pull the trigger, it releases the firing mechansim and fires the ammunition that the gun uses.
Well, except for the colors lol.
