Introduction: K'nex MP40
This is my K'nex MP40 that I just finished making. I was looking for a gun that no one had made before and this was the first one I found, so I decided to go right ahead and make it.
The only copied part is the trigger from TheDunkis's AK47 and i modified a little bit his handle.
This is my first instructable so lots of constructive criticism!
Pros...
- Small, Lightweight
- Durable
- 25+ round magazine
- Easy Firing
- Looks Cool
Cons...
- Low range
Step 1: Handle
1-Handle (Side)
2-Handle (Front)
3-Trigger Guard
4-Together
Step 2: Lower Reciever
1-Lower Reciever (Side)
2-(Bottom)
3-(Top
4-TheDunkis's Trigger
5-Trigger + Lower Reciever
6-Ready to put together handle and lower reciever
7-Together
Step 3: Upper Reciever/Barrel
1-Left Side
2-Top
3-Right Side
4-Bottom
5-Ready to attack to lower reciever
6-Together
7-Close up of trigger placement
Step 4: Magazine
1-Assembled Mag
2-Standard green rod magazine
3-Top Piece
4-Different View
5-Attached Top Piece and Green Rod Magazine
6-Ready to attach magazine to upper reciever
7-Attached
Step 5: Front Barrel Assembly
1-Left Side
2-Top
3-Right
4-Bottom
5-Ready to attach to upper reciever
6-Attached
Step 6: Firing and Rubber Band Placement
1-Magazine Push and Ram Rod
2-Magazine Push and Ram Rod in proper places
3-Trigger Rubber band goes around the rear sight
4-Ram rod Rubber band goes up to the Front Barrel Assembly
5-Magazine Push Rubber band goes around the bottom white rods and over the bottom of the pusher
Step 7: Loading and Firing
1-Load the green rods into the magazine. Fill to your hearts content
2-Push the Mag Push in then apply it's proper rubber band ( as seen in the previous step)
3-Pull back the firing pin till it locks into place
4-Take aim with the sights and FIRE!!!
