Knex Manual/Motor Gear Box
3,047
7
4
Posted
Introduction: Knex Manual/Motor Gear Box
Welcome! Here are instructions to create gearbox that can easily be set to motorised or manual. It's hard to explain so here's a video:
http://www.youtube.com/watch?v=mEJXXfG4YsE
Step 1: The Base
Yeah, everything else goes on here.
Step 2: The Motor
This section is the motor.
Step 3: Adding the Motor
The gear from the motor could mesh with another... if it's set to.
Step 4: A Bit of Support
It's easier if this is just an extra step. If not the next step is too long.
The added pieces in this picture are: 1 green rod, 1 white rod, 1 blue rod, and 1 yellow connector.
Step 5: Moving Gear
This gear shifts forwards and backwards to mesh with either the motor's gear or the manual gear.
Step 6: Adding the Shifting Gear
This clips straight onto the motor.
Step 7: The Manual Gear
If the motor jams, switch to this.
Step 8: Adding the Manual Gear
Just add the red and green connector.
Step 9: The "output" Gear
The rod is what to connect the turning part to. It could be any size.
Step 10: Adding the Output Gear
2 connections here.
Step 11: How to Use (you're Done Anyway)
With the motor facing towards you, if the trigger is left, turning is manual, if the trigger is right, then the turning is motorised.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    4 Comments
    I know
