Knex Mini Gun
Published
Introduction: Knex Mini Gun
About: I like knex and airsoft. If I find something that can explode ( like an airsoft grenade ) I would make it.
Hi, this is my first instructable. This is the Knex Mini Gun (as you can see),You can easily make this with a few parts.
Step 1: The Materials
If you look hear you will see the materials
        You will need :
8 gray top parts
1 orange connector
1 yellow rod
1 blue rod
1 gray tube
4 blue tubes
1 red connector
1 green rod (You don't need it but i reccommend you use it).
Step 2: Making the Ram
this step is very simple.All to do is attach these 2 pieces.
Step 3: Making the ' Body '
First you have to get a yellow rod, then attach 3 gray top pieces,then a red connector,and 4 more top pieces.
Step 4: Adding the Tubes
On the rest of the space you can add those grey and blue tubes.Add a grey top piece at the end to keep the tubes on.
Step 5: The Ram Goes in Too.
At the end you put the ram in the holes of the gray pieces,then double your rubber band and wrap it around the gun.
Step 6: Firing
To fire the gun you have to pull back the ram and put a green rod in the extra space in the grey top pieces.When your ready,Pull the red connector and it will fire.
    • BBQ Showdown Challenge
    • Game Life Contest
      Game Life Contest
    • Oil Contest
      Oil Contest
    9 Discussions
