Knex No Rubberbands Pistol!!!
1,122
4
16
Published
Introduction: Knex No Rubberbands Pistol!!!
About: No information given. Because there is no need for information.
Hello instructable members! This is my first instructable. It is a knex gun that requires no rubberbands. Its a true trigger (amazingly for no bands) And it goes about 15 feet max PTG (Parallel To Ground) And 20 feet ATG (Angled To Ground) at about a 40 degree angle. Well Lets start building! Thank you for 500 views on my first instructable.
Step 1: Parts
Connecters:
4 White
4 Green
2 Dark Gray (1 slot)
2 Light gray (2 slot)
2 Orange (3+ with ammo)
And 2 Reds
Rods:
8 White
10 Green
And 1 Blue
Step 2: Building the Parts
Just follow the pictures
Step 3: Attaching
Also follow the pictures
Step 4: Loading and Firing
Click the orange connecter on and add the broken red rod ( rod can be any rod but green) ( Dosent have to be broken just makes reload easy) and if you dont want to break your parts you dont need it. It just improves accuracy. Viloa! Just pull the trigger and repeat.
Step 5: COOKIE!!!
Time for a cookie. Go ahead. You have to either find it in your pocket or inside the computer.
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Game Life Contest
      Game Life Contest
    16 Discussions
    Is the orange piece supposed to shoot out
    Nice job!!!!!! I check it out and it looks pretty nice. Yay somebody took hold of my new concept!!!!!!!
    P.S. How did you get 20-25 ft.!?!?!??!?!?!?!?!?!?!? That seems impossible Thx anyway !
    -The Knexer
    Hmm... I like the idea of using the snapping force of the peices to fire. However this is not the best way of making things shoot. But it's not bad for your first gun. Try to improve the build though, by changing the handle and making the barrel longer. Good luck!
    -PotatoCoffee
    I posted this because Frist i made this whole thing up not just the mech or the shell 100% me and Second I think this is the most relible gun if you are captured in a knex war and have nothing but this. Then you can pull this out and shoot it at a guy and take his gun. Also This mech i think never fails or jams i think its 100% relible.
    The Knexer
    For war guns it's uaaualy better to have semi/fully automatic guns, as the have a higher rate of fire. Now, we have gun that are reliable strong powerfull accurate and have a high rate of fire. But then again, some people prefer single shot pistols. Anyway it was your first gun so that's okay! Have a great day! =)
    -PotatoCoffee
    And yes i know this but i posted this so people could make it and use it for whatever but they problably wont use it as a primary and i never mentioned you should use this as a primary in fact i would never even think that
