Knex Pistol UTKG (unique Trigger Knex Gun) With Mag and Unique Trigger
Published
Introduction: Knex Pistol UTKG (unique Trigger Knex Gun) With Mag and Unique Trigger
About: Retired from instructables now. I am going over to YouTube so check me out at "knextreme productions"!
Should I post instructions?
TRIGGER: put fingers on the white rod and pull towards handle
NOTE: bands are all not on
NOTE: I have made like ten of these pistols and have extremely modded versions this is just a base-It has a lot of room for modding so give credit where needed and post away
Step 1: Frame
Make this
Make frame part two times
Step 2: Internals Except Trigger
Add rails and mag parts
Step 3: Add Other Side of Frame
Just do it #nike
NOTE WHITE RODS ARE ADDED TO MAG FROM BARREL
Step 4: Trigger
Trigger it's complicated
Make it then add connected chain and the other thing
Step 5: Handle
Make it.....
Step 6: Putting It Together
Add handle and trigger plus two white rods that I forgot to show
Mag pusher ammo and rammer just figure it out genius
Step 7: Now You Are Done
Mod and repost gun and trigger all you want just give me credit as appropriate
    • Pets Challenge
      Pets Challenge
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    13 Comments
    Please put all of the sentences in one message next time, so it is easier for me to read, OK? Also, if you want to reply to one of my comments, please click the reply button on my comment, so I know that you have replied to my comment.
    I was talking about the firing pin, try to build yours like this: https://www.instructables.com/id/TR8-2013-last-upda...
    I would recommend changing the yellow connectors or the back to red ones, as the tabs on the yellows might brake, or shred the pin. If you use red connectors, it will allow the pin to gain more speed before smashing into the back or the gun. As for me being better then you at building, thank you, but trust me, I have had some epic fails.
    Honestly, while I like the idea of a different type of trigger then those that are often being posted, I don't have any plans for using it in future builds. (I remember a attempt at one of these: http://en.wikipedia.org/wiki/FP-45_Liberator that turned into a single shoot Oodammo gun, that at one point or another had a trigger like this, didn't work out so well.)
    I think that if you work at it more, you can end up posting some pretty epic things, so just keep practicing and improving older designs. I am subscribing to you. Sorry for the uber long post, just a bit of advice.
    WHAT ABOUT THE OTHER RAIL
    IT DOESNT WORK
    I took it apart and used your handle in my Hybrid Pistol. I gave credit to all parts taken from other guns
    Hey corgi could u implement a trigger like this into one of your guns ? I think it would look cool and help accuracy idk how it just does
    Sorry about pics my camera is broken and I just now realized it
    Well, it is unique like you said, but i think that you should use a different pin on it, as the one you are using looks pretty week. It could use some work, but I say post. I am sure there are people without much Knex that would like this.
