Introduction: Knex Pump Lift
Here are the instructions for the pump lift featured in Catastropha!
If you have any questions then feel free to ask!
Be sure to read all the image notes!
Step 1: The Base
You'll first make the base.
Step 2: Motor and Gearing Part 1
Now it's time for motor and gearing. You'll may be able to modify it so that it uses a different motor, but I don't think that that works as the motor needs quite a lot of power.
Step 3: Motor and Gearing Part 2
Next part of motor and gearing.
Step 4: Motor and Gearing Part 3
This is the third and last part of motor and gearing!
Step 5: The Push-track
Now you'r making the small track piece where the balls are pushed allong.
Step 6: The Pump
Now you'll be making the actual pump.
Step 7: The Turning Up
This is where the balls go from horizontal movement to vertical movement.
Step 8: The Shaft
Now your making the ball shaft.
Step 9: The Top
It's time to make the top!
Step 10: Your Finished
You just have to add six balls into the shaft and then your finished!
ShopBot Challenge
Toy Challenge 2
