Knex RGB
311
5
Posted
Introduction: Knex RGB
I enjoyed building this and I hope you do too!
Step 1: Handle
pretty straight forward
Step 2: Stock
not that good but it does the job
Step 3: Firing Mechanism
2 parts, straight forward to build
Step 4: Firing Mechanism
not really much to say haha
Step 5: Putting It All Together
step one: add the firing mechanism to the first bit of the main body. add the other bit of the mechanism on top of the the first bit, make sure the the green rod is IN FRONT of the top part of the mechanism
Step Two: add the second part of the body on to the first part. make sure all rods are pushed in to their connectors.
Step three: add the handle to the two white connectors on the body
Step 4: add the stock to the end of the gun
Step 6: Firing
pull the elastic band from the front of the gun and put it on the white connector and pull the trigger!
Step 7:
Step 8:
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    5 Comments
    It is an improvement over your previous guns, however, some tips:
    - Try to make the handle angled, and don't have rods sticking out. In a three layered handle, the white rod ends can be covered with small black wheels or other pieces, like tires etc.
    - Try to fill the gun in a bit more. In the way you have it now, you can squeeze it, because it's hollow
    - Maybe, if you have the pieces, work on the looks a bit. Not the most important thing though.
    Keep on building
    step 3 is supposed to say body and step 7 step 8 are irrelevant
