Knex Gun
2,601
12
14
Posted in PlayKnex
Introduction: Knex Gun
About: I like nachoes and tacos. My friend has personal problems
Knex Gun. Has a
"Low friction barrel
"True-trigger
"Iron sights
Range: 35-40 feet
Cons:
"Single shot
" You need a lot of brown knob connectors
"Iron sights aren't that accurate
" small handle
Note: Pictures may not be clear. I don't know how to get rid of that annoying date thing at the bottom right of the picture. If you need help, just tell me :) My first instructable so please don't be harsh.
''WARNING!!! THIS GUN USES A MODDED RED/ GREEN ROD!!!!
This gun is easily modded to have a mag or a hopper but I am too dumb to make one. I need your help!!
Step 1: Part List
Connectors:
Yellow: 4
Green: 6
Orange: 8
2 slot gray: 6
1 slot gray: 4
ball joint female: 1
black Y connector: 1
orange track splicer: 1 (optional)
blue knob: 5
brown knob: 39
White 8 slot: 3
Rods:
Green: 13
white: 10
blue : 2
red: 2 + one modded (see picture)
gray: 2
Random:
Blue spacer: 13
Tape
Some rubber bands
I think thats it... lets get building!
Step 2: The Handle
1. What you are going to make
2. Build
3.Build
4. Add step 3 on to a large pannel
5. Add the small pannel
6. Add the last large pannel
Step 3: The Barrel
1. What you will make
2. Build
3. Build ( note the modded red)
4. Build
5. Build
6. Build
7. Attach step 2 onto step 6 as shown (both sides)
8. Add step 3 onto step 7
9. Add step 4 onto step 8
10. Add step 5 onto step 9
Step 4: Trigger
2. Build
3. Build
4. Put step 2 onto 2 2 slot connectors then tape them so the green rod doesn't fall out
5. Put the 2 slot one in step 3 onto step 4
6. Put the gray one in step 3 onto step 5.
Step 5: Putting It All Together
1. Take off the green connectors on the top handle and get the trigger
2. Put the 2 slot gray connector on the trigger in the middle part of the handle
3. Put back the green connectors
4. Make sure the trigger blue goes into the hole
5. Put the handle on the barrel.
6. Make the ram. ( Its an orande connector on a gray rod taped and wrapped in bands)
7. Put the ram into the barrel
8. Add some rubber bands onto the trigger. It wraps to the other side.
9. Add rubber bands onto the ram and attach them onto the little brown knob.
10. A picture of it ready to shoot
11. Oodammo. It should lock in.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    14 Comments
    I was so confused because I wasn't sure what tan pieces you were using (I saw the tan clips and I thought that they were a version of the roller-coaster clips that come in lime green, black,...etc.).
    one of the better simple guns and great pictures dont worry about the date thing no one will care great instructable make some more guns and post up great instructions like these and you will be pretty popular around here
    can you put a gauck pistol on your site with knex
    do not fill this with airsoft bbs it will shoot but alot of bbs will come out the sides
    What can we sub out for all the tan colored pieces on the barrel??
    You could try blue pieces (they are right next to the tan pieces) or y connectors, which are black and Y shaped.
    Nicely done! Mine>> yours great howtos!
    i think he did the end with the stopper
     great job, with a block trigger!!!!!!! dude 4.5 stars for U!!!
    how much do u cut of
    very very bery nice gun thats the gun i whas looking for thanks
    Its decent. If you want to know how to build a mag for this gun, check out my AR-4 v3, it has a similar barrel.
