Knex Semi Auto Rubberband Gun
7,319
11
36
Published
Introduction: Knex Semi Auto Rubberband Gun
Welcome to my instructable this is the first ive done so please give comments for improvements and if you have any trouble making the gun just ask.
Step 1: Parts
  1  white moon connector
10  yellow half moon connector
  2  green 4 point connector
  5  red 3 point connectors
  1  grey 2 point connector
15  green rods
12  white rods
rubberbands
Step 2: Body
First make the outer case make sure you make two
Step 3: Internals
These are the parts you need to make
nothing else really to say about these except make them
Step 4: Inserting the White Rods
put the white rods in each part
Step 5: Putting It Together
Picture one is the trigger mech at the at the angle in the gun
Picture two is the end of the barrel where the rubberbands go round
Picture three is the bottom of the handle to keep the gun rigid
Step 6:
next put the other casing  on the other side
Step 7:
Finally the rubberband placement on the trigger make sure they are tight
and youre are done if you have problems with just put a comment thankyou
    • Oil Contest
      Oil Contest
    • BBQ Showdown Challenge
    • Clocks Contest
      Clocks Contest
    36 Discussions
    i built it at home and it doesnt work
    but figuretively it would work
    keep up thy good work
    When I pull the trigger, the circle connector won't spin. Even if I don't put any of the rubber bands on the trigger, it is still stuck.
    Thanks dom
    Dude this is awesome great ible
    I don't think that anyone would be short a green rod. You can take apart other creations if you don't think they are too good.
    Every time i pulled the trigger, the 2 way would get in the way of the white connector, thus making it now spin :/
    ok try and put more rubberbands on the trigger to make the grey connector to be pulled back to the original position ( before being pulled )
    Why should he? He isnt going to try to make the "perfect war gun". This is just a small rbg.
    He has a point though. RBGs are just as good and more fun for shooting indoors.
