Terms and Agreements:
Any pain inflicted by this "gun" or by your own idiocy while attempting to build the "gun" is not my fault. Deciding to shoot your friend/your toy/your pet/yourself is your decision and your decision alone, though there is always the influence of others. I cannot and will not accept responsibility for your actions, unless I, in any way, shape, or form influenced you directly within a distance of 10 yards (9.144 meters) of you to shoot your friend/your toy/your pet/yourself, etc.This is not a toy. This is a potentially lethal weapon.
This "gun" is built from two parts: the magazine/feed and the barrel (ram included). A couple of things you will notice about this "gun" are that it has no stopper/blocker/whatever the thing is called that stops the ram; it jams readily if not fired correctly (and if you just aren't lucky, but it is easily unjammed); by shotgun I mean 2 bullets at a time (you will realize how annoying this turns out to be later); and, finally and most importantly, the magazine is detachable (meaning you can remove it and attach a fresh one instead of having to constantly reload!!! OMGZORZ!!!!).
Note: Any list of required pieces is the list of pieces I used to build my version of the "gun." Certain pieces can be exchanged for others.
Special Thanks to: (your name here), an actual Instructables username, for the amazing magazine design. You will notice that I modified it slightly.
Remove these ads by
Signing UpStep 1Constructing the Barrel and Ram
Ram:
1 black rod
1 tan clip connector
1 red connector
1 orange connector
Barrel:
2 yellow rods
1 red rod
8 orange connectors
7 red connectors
2 grey connectors
1 white connector
The ram is self explanatory.
For the barrel, just attach the many pieces onto the single red rod.
Please excuse the blurry pictures.
semi meaning pull the trigger back and firing and auto meaning when the trigger is replaced at its place it has reloded automaticly !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It is not semi auto because you have to cock it before firing. This system is called a "bolt action gun" or "repeater". A block trigger does not change anything to that. (neither does a true one.) This is a semi auto gun: http://www.instructables.com/id/TrueSemi-automatic-Knex-pistol./
