Knex Sf-13
315
Published
Introduction: Knex Sf-13
Hello, this is my knex sniper, or precision rifle. It is 1.20 meters tall, or 4 feet. It is very resistant, given the metal reinforcements. Its range is about 70 feet, (20 meters), although it is accurate for up to 30 feet. Its mag isn't removable, but with a medium size it supports 10 blue rod rounds.
It also has a carrying strap. It uses 5 +- cut parts, but they aren't necessary, since they are for comfort reasons, and not functionality. Its only con is the high part count.
It uses 2 long rubber bands, bought on the knex website, 1 small for the trigger, and another one for the mag.
The mags size can be adapted to suit your needs, (small = 4, medium = 10, large = 15-20 +
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    13 Comments
    I like where this is going, with the sights accurate for targets 30 ft away. Sweet! In real life I can't hit anything regardless of what gun I use, virtually I'm a pretty good sniper though.
    Sumrd, it's long because the barrel increases accuracy, and I don't care about the mobility. I use the metal rods so they support the pressure of the bands, if it were plastic, and it would snap. And it looks better, thanks anyways
    Thanks westmarch for the tip, but I use my phone, so no reply button, thanks for the advice
    quite impressive, but i can c 4ft being very clumsy to handle...and idk bout everybody else, but i dont have metal rods...it needs a removable mag (IMO)...otherwise it looks awesome and great for sniping
    Not bad bro...BTW, use the "reply" button at the top right of every comment if you want to reply directly to somebody's comment.
    Thanks awesomest I've tried different weapons styles (smgs, pistols, lmgs), but I prefer the evil of a sniper
    you are good man I see a lot of good stuff coming from you
    Thanks Sandro i worked for 10 hours on it although I'm still improving it a lot Later ill post an updated version of it
