loading
Hey peeps! Shadowman39 and Tornado96 are back with our second collaboration, the shifting arm lift!
This lift uses two sets of arms that alternate on going up and down. The balls are shifted from one side to the other when the arms move. It uses a double crank at the bottom and a gate system to keep the balls in the lift.
Note: this lift works with both the original and newer Knex balls, but it isn't reliable with the newer balls. Modifying would be a good idea if you want it to work better with the newer balls.
IMPORTANT:
Push the switch of the motor inwards for smoother movement.
Here's the video of the lift in action:
Direct video link
http://www.youtube.com/watch?v=E6haOsTXlN8
So, if you want to build it, let's shift to the next step!
Step 1: Piece Count (Optional)
Well, you won't get very far without pieces will you? So here are the pieces you'll need to salvage to build the lift.
Rods: 294
green- 58
white- 67
blue- 93
yellow- 34
red- 32
gray- 10
Connectors: 244
dark gray- 40
light gray- 1
red- 28
green- 32
yellow- 38
orange- 24
white- 9
blue- 15
purple- 57
Other: 89
blue spacer- 26
silver spacer- 28
tan clip- 7
Y clip- 24
small blue/brown gear- 1
red gear- 2
newer-style battery-powered motor (green)*- 1
Total: 627
*You can use a different motor if you wish, but you'll have to modify the motor section.
<p>Nice lift! I think I will use this in my next ball machine if I can get it to work with a green motor.</p>
<p>Thanks! The version of the lift in this Ible uses a green motor, so you shouldn't have to do much modifications.</p>
<p>BTW, what is different about the newer K'NEX balls?</p>
<p>The newer balls are slightly larger and lighter than the original balls.</p>
<p>Oh, I see. Thanks!</p>
<p>You're welcome! :-) I now have a couple of tethered motors, so I don't have to modify it.</p>
<p>the ball always falls of at the 3rd arm and doesn't reach the 4th arm :( what do I do?</p>
<p>I'm sorry to hear that, did you try the modifications in step 11?</p>
<p>I added a yellow rod instead of a blue one, it now works. thanks though</p>
building it but it keeps jamming and snapping for some reason. any idea why?
Maybe it will fix itself when it's done. the problem is that the entrance bit(the one right in front of the motor that is step 1 on the guard bit ) gets pulled down too far and goes vertical, stopping the crank from working. I'm hoping once the arms are in, they sort of pull the entrance a bit. anyway, I remember building this years ago (before I had Instructables) and had the same problem. anyway this gr8 lift will be in my next ball machine :D
Built it! Really simple fix, Add a yellow rod here (The one that goes through 3d connector and stops just before the snowflake)
And now I have built the entire ball machine and this lift doesn't work...:(
<p>Sorry for replying so late, I bet by now your machine is already posted. </p>
<p>Nice lift! Not very many pieces either which makes it ideal. Nicely done!</p>
<p>Great Model</p>
<p>That's looking nice, thanks for building!</p>
mine keeps stuffing up. For some reason the cranks and the gatekeeper are at the wrong lengths, and they keep stopping the motor <br>
Do you have a picture of that crank area?
oops no fixed it <br>
Yay!
I made it. Works good. Looks to be a good addition to my machine.
Nice! Looking forward to seeing pictures.
Sent pics. A note for future builders, I replaced the blue rod on the arms with yellow rods and it improves reliability.
I uploaded the pictures but they were rotated the wrong way, even when I rotated them myself. I'm not sure what the problem is.
Nice one! :D <br>How come you guys do so many collabs recently? :P
Thanks! We've only done two collabs, I wouldn't call that a lot. :-P
What about the other 3141592653589793238462643383279502884197169399375105?
Did you memorize those?
erm, yes.
Nice :-P
no, not nice, i once knew far more.
I only memorized the first 6 digits, lol.
i once knew 108<br>the key to knowing pi digets is boring biology lessons. don't question me. never.
Biology was boring for me as well. :-P
It was only boring to me due to slow pacing in the lessons.
I knew there was something fishy... those are the digits of pi
jup, lol
We never posted those collabs. :-)
what other types of balls can i use, i dont have those,
If you don't have Knex balls, you could try golf balls.
wow! <br>I'll use this(hopefully)on my next ball machine <br>:-)
Cool, thanks!
you're welcome!
nice!. it works with the black white balls?.
Thanks, and yes it works with those balls, but not as accurately, so you'll have to modify a bit.
it works with the black/white balls i did`nt modify anything
That's good. When we tried it out it wasn't as accurate, so I guess it's different for other people.
hahahahaah okay :)
Looks good. :)
About This Instructable
9,919views
29favorites
License:
Bio: On my page you'll find lots of different Knex projects, from ball machine lifts to useful items. I hope you enjoy! &nbsp;_______________________ Current avatar ... More »
More by Shadowman39:Knex Vertical Jigsaw Lift Citadel Knex Ball Machine Elements - Instructions Citadel Knex Ball Machine
Add instructable to:
