Introduction: Knex Shotgun
Hello, and this instructable is to show you how to make AdamsDead's Shotgun. I know you have all been waiting for a long time now. Well its because I've been busy with school and stuff. So I hope I have enough Pictures and they are clear enough. :)(Mods)
Step 1: Trigger
This is the trigger for the gun obviously. You may recognize it.
Pic 1: Make This.
Pic 2: Make That.
Pic 3: It's Different from pic 2 so make that.
Pic 4: Connect Pic 2 and 3 in the correct places. Also add the gray rod to the green connector in Pic 2.
Pic 5: Attach Pic 1 to the gray rod in Pic 4.
Step 2: Barrel and Hopper.
THis will tell you how to make the barrel and hopper for the gun.
Pic 1: Make.
Pic 2: Just there to help you make pic 1.
Pic 3: Make. ( Not Hard )
Pic 4: Other side of Pic 4.
Pic 5: Attach as seen in the Picture.
Pic 6: (Yes I know I forgot to add this before the Hopper).
Pic 7: Again there to help you make Pic 6.
Pic 8: That part is crucial.
Pic 9: Connect Pic 6 to Pic 1.
Pic 10: It should look like That.
Your done with this section. :)
Step 3: Firing Pin and Pump
This part shows you how to make The pump and firing pin.
Pic 1 and 2: Make.(Same thing)
Pic 3: Add 2 grey rods with 3 blue spacers.(Grey rods are the guides.)
Pic 4 and 5: Make.(Same Thing)
Pic 6: Put Pump on like so.
Pic 7:How to attach it to barrel.
Step 4: Body and Stock
THis is the Body and the Stock.
Pic 1: Make.
Pic 2: Make another Pic 1 just add the orange connectors in the right place.
Pic 3: Fully connected.
(I would suggest Not connecting the stock and body till after everything else is connected.)
Pic 4,5,6, and 7: Make This. It's 5 layers thick.
Step 5: Attaching It All Together and Rubber Band Placement.
OK this is the easy part.
Pic 1: Attaching the Trigger.
Pic 2: Slide it in there.
Pic 3: Slide the other half and connect the two.
Pic 4: It should look like that. NOw you need a Blue rod.
Pic 5: A little blurry but insert it like so.(Make sure it clicks)
Pic 6 and 7: Attach barrel, pump, firing pin, and guide like so.
Pic 8 and 9: Attach stock.
Pic 10: Attach rubber band for trigger here.
Pic 11 and 12: Pump rubber band goes here.
Pic 13:
Step 6: Finished!!!!!!!!!!!!!
Now have fun with your new shotgun. I will like to give thanks to AdamsDead for letting me post his gun. Now please if anyone could let me now if I did something wrong or forgot something please don't be afraid to tell me. Well Have Fun :).
