Knex Simple Modified Stepper Lift by collinjo12
This is a simple version of 39shadowman's Modified Stepper Lift orginally built by Thibaultisthebest. This one is a remake of speedydog550's stepper and has instructions. Wow! What a surprise! This lift is based on the original stepper lift that was in a Knex set, except it doesn't use as much friction when the carts have to slide on rods. Instead, the carts are on small towers that are attached to axles.
HERE'S the lift IN ACTION:
Step 1: The Base
Gathered your pieces for building with the newer black/white balls? Good, let's start out with something simple. Building the bottom of the whole structure. You NEED to look at all the pictures in every step even this one to be sure of everything. Right?
roelmarco says: Oct 9, 2012. 12:07 PM
The transmission from the motor to the shaft kept hitting the shaft, but I fixed it. Wanted to upload a pic but my copmuter wouldn't let me :(
Speedydog550 says: Sep 3, 2012. 7:12 AM
mine worked with older balls, i dont see why this wouldnt, maybe you will have to modify the ball loader, and possibly (but i dont think so) the exit track.
KneXtreme says: Jul 18, 2012. 4:07 AM
Nice lift. But it seems like that big wheel thing at the bottom might get in the way when you use the lift in a ball machine. Also, it seems quite jerky.
collinjo12 (author) says: Jul 18, 2012. 7:58 AM
Thanks. But no, because as you see in my video, the small light green rods on the second ball claw can push back the dispenser if it accidentally stays tipped forward.
KneXtreme says: Jul 18, 2012. 4:00 PM
No, I mean the way the wheel thing sticks out might get in the way. I meant the small towers themselves are quite jerky.
collinjo12 (author) says: Jul 18, 2012. 4:04 PM
Well that's how I saw it in speedydog550's Iron. Works fine.
P.S where do you live
Speedydog550 says: Sep 2, 2012. 6:39 AM
Yeah when I first built it I tried making it smaller but because of all the pieces on the front of the tipper thing the back needed to be quite heavy so it falls back down therefore it sticks out quite a bit but it was still fine when i finished the ball machine: http://www.youtube.com/watch?v=twRv9wLpghA&feature=plcp
collinjo12 (author) says: Sep 2, 2012. 8:24 AM
THANKS!!
Speedydog550 says: Sep 3, 2012. 7:05 AM
no problem, and by the way well done on re-creating my design with only the tiny footage in my video, really nice result
KneXtreme says: Jul 19, 2012. 6:57 AM
Okay. I don't want to give out specifics over the internet, but let's just say I'm moving to Texas in about a week.
Sorunome says: Jul 17, 2012. 2:36 PM
Nice version of the lift!
It uses a lot less pieces, lol
collinjo12 (author) says: Jul 17, 2012. 3:19 PM
Thanks, and I mentioned that I didn't come up with this idea.
Sorunome says: Jul 17, 2012. 3:24 PM
meh, seems like i'm to tired to post, i meant that it is a nice piece-let version of shadowmans lift
(sorry, after midnight here, lol)
Speedydog550 says: Sep 3, 2012. 7:03 AM
thanks, i tried to make it as least piece consuming as possible
KGuy says: Jul 18, 2012. 10:55 AM
Wow! Nice Job!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
