Knex Slugg 220 Rifle
5,311
Published
Introduction: Knex Slugg 220 Rifle
Hey peeps. First instructable, woo. This gun has a 90-100 foot range with capped ammo. Block trig, but cool. Also has auto-lock. Its muzzle-loading but im gonna do research on making a mag to hold some rounds. Sweet gun tho.
Step 1: The Barrel
Just do what the pictures say. There is a close up view on the green connectors just count and see how many u need for that part.
2nd pic: that's a black Y shaped connector on the trigger (the orange connector to the far left. the black connector isnt hooked on to the grey rod it just looks like it is.
3rd pic: Oops! I cut it out but theres a green connector on the bottom behind the orange connectors.
Step 2: The Firing Pin
Simple. Once u connect the orange connector and the grey rod, slide a grey spacer down the grey rod, attach the yellow rod, and duct tape spacer and all on that side of the connector.
Step 3: Handle and Stock
The pictures explain alot. But make sure to add a blue rod for extra support between the two halves.
Step 4: Rounds
The gun fires capped green rods at high speed( high enough speed to give me a small red mark on my leg). All you do is take roll caps, cut around the cap you want to use so its small enough to fit onto the end of the rod. Then just use a bit of tape to tape over the cap. Simple, but awesome.
My thanks go out to kruser495 for the invention of these awesome rounds. Tyvm, dude. Heres the full instructable on how to make them.
Kruser Round
Step 5: Rubber Bands
Sry, no pics. My web cam died just before i could take the rest of them. But anyway, for the auto-lock, just hook a rubber band on the block trigger and pull it diagonally across to the muzzle of the gun. Hook it on there to the end of the left grey rod.
For the firing mechanism, just hook 3 or four (im using three for 100ft range) rubber bands on the last notch of the firing pin connector, pull it between the two sides of the stock, pull it along the underside of the barrel, thru the two bendy rods, and hook it onto the small v shaped notch between the two free connector notches on the front green connector.
Step 6: Loading and Firing
To load the gun, just grip the yellow rod sticking off the end of the firing pin and pull the pin back until the auto lock goes off and the trigger sets. Load your capped round with the cap side entering into the barrel first. Only push the round in far enough that it is ONLY JUST concealed by the muzzle of the gun. If you ram it in the firing pin wont set the cap off. Just push the trigger and bam! The round travels 90-100ft! Dont forget to look for the shot because the blast doesnt destroy the rod!
Happy Shooting!!
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    27 Discussions
    i like it, but what is with the curvy part on the barrel/handle?
    this is just simply a killerk copy with a long barrel. i also highly dout that it actually shoots 90-100ft. only the most advanced guns can shoot that far. and this is definitly not an advanced gun.
    90-100 foot range??? i don't beilve you, radioactive's SPEC-9 goes 60-100 feet mostly because its a slingshot gun, but this is a ram gun.
    wow thats sure a far shooting gun but I don't really like the looks so I built it like a rifle and mine only shot 37 feet and 2 inches
    oh yeah..... try usin killerks pistol with the green capped ones. you see the explosion come out in a line from the barrel. =)
    hi ive been using capped green rods made exactly the same way before this instructable. nice to see another person who made up the same idea.
    Its not that great with normal ammo, even with extra rb's. I insist on the use of kruser rounds. they rock my sox. It only goes about 20 ft with normal rounds.
    My gun that only takes 22 pieces can shoot about 30 feet. Try adding some more rubber bands. I'ts a pretty good gun for a first instuctable. :)
    are you sure only 20ft with uncapped? i n got caps.(sorry for grammar mistakes)
    i finally finished it YAY. but the first time i fired it it snapted the firing pin and broke the whole gun into 3 pieces
    C:\Documents and Settings\AJ\My Documents\My Pictures\2007_10_18\IMG_1292.JPG
    dude u need a better camera
