3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knex Tower Crane
Knex Tower Crane
It's finally posted! Here is a tower crane I made one weekend that is about 75 inches (6.25 feet) tall. It has almost every function off a real tower crane. It can rotate 360 degrees, the trolley moves from the tip of the jib, all the way back to the tower, and the hook can lower all the way to the ground no matter where the trolley is. Even though the crane can only lift a few ounces, it was a build that I really enjoyed, and (if you have the pieces), I hope you will build and enjoy too! Feel free to make any adjustments or modifications to the crane.
Please rate and comment.
Step 1Pieces Count
This tower crane is very large and uses MANY pieces, so it would be a really good idea to make sure that you have all the pieces before you start building. Note that the count may not be 100% perfect, but should be very accurate.
Connecters:
Gray (1 slot): 3
Gray (2 slot): 6
Orange: 142
Red: 17
Green: 6
Yellow: 29
Silver Slide: 272
Blue Slide: 52
White Circle: 43
Bars/Rods:
Green: 154
White: 131
Blue: 238
Yellow: 259
Red: 151
Gray: 13
Other:
Brown/Tan Clip: 13
Blue Clip: 36
Black Hinge: 4
Blue Spacer: 50
Silver Spacer: 105
Micro Chain Gear (Black): 4
Micro Gear: 2
Large Gear: 1
Medium Gear: 2
Small Gear: 1
Big Wheel: 5
Big Tire: 0
Small Wheel: 4
Small Tire: 4
Motor: 3
Chain Links: 162
String: 20-25 feet
Marbles (optional): 70-90 (depending on size of load)
9 comments
Mar 7, 2012. 1:30 PMTubaJ446 says:
hey, the rotating mechanism on mine seems to not support the weight of the tower, it bends and the axle rods snap out of place. Do you have any ideas?
Feb 4, 2012. 7:14 AMmellorpat says:
Just finished building your crane shortend the front by two blocks and but them on the rear still had to add weight to rear but looks good. My grandson will love this. thanks.
Jan 16, 2011. 6:11 PMFerangi51 says:
cool
Jan 16, 2011. 2:13 PM~KGB~ says:
nice
Jan 16, 2011. 12:51 AMfuzi says:
what 3 motors do you need
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:MrSmashCat
Iv'e been making stuff with k'nex since I was really young. If you have anything you'd like intructions for, let me know and I'll try to make it! Check out my YouTube channel: http://www.youtube.com/u...
more »
