K'nex Tricopter Model!!!
1,528
4
9
Published
Introduction: K'nex Tricopter Model!!!
About: Hello! I'm Nerfrocketeer, also known as Nefrock', Nerf, or NK. I am an avid fan of Nerf wars, engineering, and animal activism (but no I don't go overboard). Thank you for A MILLION views (woah!) and making ...
After building my K'nex quadcopter model, I became fascinated with other kinds of multirotor drones. I already knew I wanted to build another model, and when I saw the tricopter, I knew it was the perfect thing to build. When finished, the tricopter was just as realistic as its four-armed couterpart, this time featuring a central suspension and four-bladed rotors, all while being an actual-size replica. In this Instructable I am going to show you how to replicate my building process and build your own K'nex tricopter model!
The beginning of the story can be found here.
Step 1: Parts
You will need:
-15 white connectors
-18 blue connectors
-66 yellow connectors
-12 green connectors
-18 red connectors
-62 grey connectors
-4 light grey connectors
-2 orange connectors
-5 blue separators
-16 blue caps
-23 grey separators
-4 black caps
-4 grey rods
-12 green bendy rods
-4 yellow rods
-4 orange bendy rods
-6 red rods
-6 blue rods
-12 purple bendy rods
-99 white rods
-213 green rods
Step 2: Center: Pieces
Take a grey connector and a blue connector and slide them together. Repeat to get six pieces.
Step 3: Pair Up
Add two white connectors to the group, then pair the pieces up as shown. Next, connect the pairs using green rods. Finally, arrange the pieces in a square exactly as shown.
Step 4: Red Connectors
Take four red connectors, and attach them to the pairs using green rods to make a square. Repeat steps 2-4 to get two squares.
Step 5: Stack and Connect
Stack the two squares as shown and connect them using green rods.
Step 6: Top and Bottom: Pieces
Take two grey connectors, and slide them together. Repeat to get eight pieces.
Step 7: Pair Up
Pair up the pieces you have just made and connect them using green rods. Next, arrange the pairs in a square as shown.
Step 8: Red Connectors
Take four red connectors and add them to the pairs to form a square. Repeat steps 6-8 to get two squares.
Step 9: Add Top and Bottom
Using green rods, add each of the squares you just made to the top and bottom of the other two squares as shown.
Step 10: Top and Bottom Covers
Take four white connectors and arrange them in a square. Next, connect them using green rods. Repeat to get two pieces.
Step 11: Add Top and Bottom Covers
Add the pieces you have just made to the top and bottom of the center piece.
Step 12: Fill in Spaces
Fill in any spaces using white rods. Make sure you have done it exactly the same as in the pictures!
Step 13: Purple Rods
Add purple rods to the corners to fill in spaces.
Step 14: The "Antennas"
Take a grey rod and attach a light grey connector to it. Next, add an orange bendy rod to the light grey connector. Repeat to get four antennas.
Step 15: Adding the Antennas
Insert the grey rods through the holes in the red connectors. Next, click rhe orange bendy rods into pmace in the white connectors on the top. Finally, add black caps to the bottom of each grey rod.
Step 16: Center: Check
The center is now complete! Check to make sure it looks like the picture!
Step 17: Arms
Take eight yellow connectors and connect them using green rods. Repeat to get two pieces, and connect the two pieces using green rods.
Step 18: Arm Tips
Take two green connectors and connect them using a green rod. Next, attach them to the end of the arm with green rods.
Step 19: Upper Arm Connector
Take two grey connectors and slide them together. Repeat to get two pieces. Next, connect the two pieces using a green rod. Then, add two white rods and two grey separators.
Step 20: Attaching the Upper Arm Connector
Insert the white rods in the fourth yellow connector from the end without the green connectors. Next, add blue caps to the underside of each rod.
Step 21: Upper Arm: Back
Take three yellow connectors and connect them using green rods. Repeat to get two pieces. Next, connect the two pieces using green rods, and add it to the upper arm connector as shown.
Step 22: Upper Arm: Middle
Take two red rods and attach them to the upper arm connector.
Step 23: Upper Arm: Front Connector
Take a blue connector and a grey connector and slide them together. Repeat to get two pieces. Next, connect the two pieces using a green rod. Then, add two white rods and two grey separators to the pieces. After that, insert the white rods through the last yellow connector as shown and add blue caps. Finally, connect the two red rods.
Step 24: Upper Arm: Front
Take two green connectors and connect them using a green rod. Next, attach it to the front of the arm.
Step 25: Blue Rods
Add two blue rods to the front of the arm as shown.
Step 26: Rotor Holder
Attach an orange connector to a yellow rod as shown. Next, add on a white rod and a grey separator. Then, add blue and grey separators to each side of the yellow rod. Finally, attach the yellow rod to the front of the arm.
Step 27: Rotor
Take a white connector and attach four green bendy rods as shown.
Step 28: Attaching the Rotor
Attach the rotor to the white rod on top of the rotor holder and add a blue cap.
Step 29: Fill In
Step 30: Repeat
Repeat steps 17-29 to get two arms.
Step 31: Attaching the Smaller Arms
Attach the two arms you have just made to the center using green rods. Next, fill in spaces using white rods.
Step 32: The Third Arm
Repeat steps 17-25 to make another arm frame, except this time, the two sides are connected using white rods, to make the arm wider.
Step 33: Third Arm: Tips
Take two red connectors and attach them to the end of the arm using green rods.
Step 34: Third Arm: Rotor Holder
Take a yellow rod and attach it to a blue cap. Next, insert it through the holes in the two red connectors. Add three grey separators between the two connectors, and two grey separators to the top.
Step 35: Third Rotor
Make a third rotor by atracuing four green bendy rods to a white connector. Next, add it over the rotor holder, and add a blue cap.
Step 36: Yellow Rod
Add a yellow rod to the front upper arm connector.
Step 37: Fill In
Fill in all spaces using white rods.
Step 38: Third Arm: Attach
Attach the third arm to the center using green rods.
Step 39: Done!
Congratulations! Your K'nex tricopter is now complete!
The story ends:
Now having satisfied my curiosity with the workings of multirotor drones, I now have a lot of new knowledge! One question still remains: can anyone make this fly? Anyone who can gets a patch and sub from me!
Thanks for viewing! Enjoy!
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    9 Comments
    Yeah, me too... But to change it up a bit, (cause I know you're getting tired of hearing me say "thanks!") I'll say it this way: Bedankt! ;)
    Haha bedankt to say it with anothor word, phewww =D
    How did I miss this??? This is pretty cool, but man... That thing uses a lot of bendy rods. :3 Getting this thing to fly, I'd think, would require a much lighter box in the center, and most likely tape all around the wings and box so air doesn't leak right through it. Nice job!
    Well, actually tape would make it heavier. But i think ot could fly. :P multirotor drones dont have to be airtight... :P :3
    Haha cool, must have been sorta hard trying to position the wings into three even places!
    Oops... I totally forgot to click the reply button there... Sorry...
    Thanks! I tested out the idea using blue rods on a white connector. ;)
