3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Knex Ultimate Drumsticks!!!
These are Knex drumsticks i haven't built drums yet but you can use pots and pans.
Pic#1 The drumsticks.
Pic#2 Showing the heads of the sticks.
Pic#3-4 Assembly (Get a gray rod and a gray connector and connect them).
Step 1Construction
Construction
The sticks are really easy to build what you need to do is.
Get a Gray rod and a Gray connector.
Hover the Gray rod over the Gray connector and push it down. (Do this twice)
And your done!
16 comments
Sep 8, 2009. 1:44 PMadmin says:
This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do. 1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable. 2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made! Thanks for your submission and let me know if you have any questions along the way.
Oct 24, 2009. 1:06 PMKiller~SafeCracker says:
Take this out of the highest rated instructables group. Last time I checked this was no where near 4 stars.
Nov 1, 2010. 11:35 AMSenior Waffleman says:
dido
Nov 30, 2009. 6:59 PMBerkin says:
I suggest making something that requires more than 2 pieces.
Sep 27, 2009. 12:35 AMSkreetsha says:
This is insulting to the K'nex community, we can make two pieces snap together y'know?
Sep 10, 2009. 5:43 PMdsman195276 says:
I find that using a grey rod with a tire on the top makes the best sound with a real drum set...
Sep 12, 2009. 7:32 AMBartboy says:
You can also make "brushes" with a bunch of grey rods and elastics
Sep 12, 2009. 9:42 AMdsman195276 says:
hmm, I never thought of that, good idea!
Sep 12, 2009. 11:12 AMBartboy says:
It doesn't work so well on the snare, but it makes the cymbals sound cool. Do you have a drum kit?
Sep 12, 2009. 11:31 AMdsman195276 says:
Ya. I also play snare in marching band.
Sep 12, 2009. 1:03 PMBartboy says:
What type of drums do you have?
Sep 12, 2009. 12:49 PMTwistedParadox says:
Wow, you must be some kind of "Ultimate K'nex Master".... (/sarcasm)
Sep 11, 2009. 3:55 PMShadowman39 says:
Seriously, this doesn't need an Instructable; all you need to do is snap one piece to another.
Sep 11, 2009. 2:05 PMDJ Radio says:
Connecting a part to another part does not make for a very good instructable.
Sep 10, 2009. 12:49 PMcyclonef says:
Is this a serious instructable...
Sep 9, 2009. 3:31 PMDaniel662000 says:
Cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Knexmasterultimate662000
