Introduction: Knex Vertical Jigsaw Lift
Picture of Knex Vertical Jigsaw Lift
Hey everyone! This is a lift that was originally in Citadel, the Vertical Jigsaw Lift! It's much like a normal jigsaw lift, except it's going straight up instead of diagonal, which saves space and time. A rotating center section which looks like a jigsaw blade goes around with the help of a counterweight, and the balls go up a freefall step by step.
The design for the main parts of this lift were invented by Tornado96, who gave me permission to complete the design (adding the motor and tracks) and post the instructions.
This lift can be made taller than the one in these instructions; just make sure to extend the driveshaft in the back (more info on this in Step 5).
Here's a video of the lift in action: (direct link)
Note: This lift only works with the older Knex balls (the ones that come in two halves), since the newer balls are too big to fit into the freefall without modification. You'll have to change it to work with the newer balls.
If you want to build it, let's move to Step #1!
Step 1: Get the Pieces
Picture of Get the Pieces
Like most first steps, you'll need to gather pieces for the lift before building anything. The parts list for my version of the lift is below, which will be covered in these instructions. If you don't have enough pieces, you can modify yours to use less. For example, you can use all red gears if you don't have yellow ones (like in the second picture), and you can also place the counterweight in different locations so that part doesn't use gears at all (as seen in the third picture). You can also leave the counterweight out altogether, but the lift movement will be less smooth. I'll say more about these modifications later, in Steps 5 and 6.
Rods: 297
green- 104
white- 68
blue- 92
yellow- 23
red- 7
rigid tan- 3 (not required, but recommended)
Connectors: 242
dark grey- 27
light grey- 8
red- 43
green- 16
yellow- 53
orange- 28
white- 9
blue- 14
purple- 44
Other: 113
blue spacer- 53
silver spacer- 22
tan clip- 8
Y clip- 10
small blue/brown gear- 1
medium red gear- 3
medium yellow gear- 3
small wheel- 5
small tire- 5
medium wheel- 1
medium tire- 1
newer-style battery-powered motor (green)*- 1
Total: 652
*You can use a different motor if you wish, but you'll have to modify the motor section.
Step 2: Main Tower
Picture of Main Tower
Did you get some pieces? Excellent! If you don't have them all, you may want to double-check the checklist. And, after doing that, triple-check the checklist to make sure you were correct when you double-checked the checklist.
Anyhow, let's begin the lift by building the main tower. It's a freefall with little holders along the way so the ball doesn't fall back down. Though it's a freefall, the ball doesn't actually do any falling... so I guess it could be called a freerise?
With all the pictures, there's an image note that explains the particular picture, rather than a list in the step description. This way you won't have to constantly close full-screen mode to read the explanations. Let's get started shall we?
Step 3: Base and Entrance Track
Picture of Base and Entrance Track
Now that you've completed the main tower, it's time to strengthen the base. You'll also add the entrance track, which is simple; no gatekeeper on this one, the balls can go right into the lift without a problem. I suppose he's on vacation to go guard the shifting arm lift instead.
Step 4: Supports and Exit Track
Picture of Supports and Exit Track
More supports! These will help prevent the tower from getting too wide or narrow, since there's an open side. If the tower were to get too wide, the balls would fall down out of the holders, which would be disastrous. Who knows what could happen, they might implode or something. In addition to these tower supports, the exit track will be added. After all these supports you'll finally be ready to build what you've been waiting for: the jigsaw! (Unless you like to build supports more).
Step 5: Jigsaw
Picture of Jigsaw
This jigsaw sits in the middle of the tower and rotates, so make sure it can rotate freely and not slide on the crank rods. The light grey connectors should also be kept straight, so they can assist in the lifting of the balls of the machine.
After inserting the jigsaw, you'll link up the top and bottom crank with a driveshaft. You can use other methods to link up these two cranks, such as a geartrain or chain (an example of the geartrain method is in the last picture). I just like the drivehaft method since there's less friction and it's easy to extend. If you're making your lift taller, be sure to connect more than the top and bottom cranks to the driveshaft (you'll probably want to connect to the driveshaft every 2 red rods). As stated in the first step, you can use only red gears if you don't have any yellow ones. Go to picture 20 for how to use red gears only.
Important: After building the linkage of your choice, you'll have to adjust the cranks that are linked up. To do this, slowly turn the jigsaw from the bottom crank by hand (turn it in the direction that it will be moving when finished, not backwards), and make sure the jigsaw runs smoothly all the way around. You especially want to watch out for when the jigsaw reaches its highest point and starts lowering. If it jumps past the top, adjust the timing of the gears so that one crank is at a different time than the other. The reason you have to do this is because of twisting in the driveshaft.
Sorry for the wall of text; there's a bug with using the enter key. At least it's not velociraptors.
Step 6: Motor and Counterweight
Picture of Motor and Counterweight
Now that the jigsaw is finished, it's time to add in the motor. If you adjusted the jigsaw well in the last step, you won't have to adjust very much things in this step. When turning on the motor (which you will likely do right after installing it), press the switch towards the jigsaw. Just keep in mind that, if you switch it on before adding a counterweight, it will strain to lift the jigsaw more than Tornado96 strains when he tries to do push-ups.
Step 7: You're Done!
Picture of You're Done!
Hooray, the vertical jigsaw lift is now complete! Now just press the motor switch towards the jigsaw, add some balls, and watch it go! As always, if you have any questions/comments/concerns, leave a comment below.
Thanks for viewing, and happy building!
-Shadowman39
KnexProductions (author)2017-06-15
I love this lift, gonna use it in my ball machine now :D
Sweet, thanks!
Hiyadudez (author)2017-04-15
That's pretty awesome. Nice to see you're still going at it.
Whenever I come back onto here every 6 months or so I always check out the new Knex stuff and part of me wishes that I had the time to just buy a huge bunch of Knex and start building again. I'm sure I could materialise much more complex ideas than I could 5 years ago, but I don't see that in my future to be honest :(
Good work.
Shadowman39 (author)Hiyadudez2017-04-16
Thanks man! I didn't expect to see you comment, haha. The best way to collect Knex is gradually, as the large lots are usually too expensive anyway. Are you busy with school?
Kipcorn (author)2017-04-09
Thanx for sharing this, I love it!
Shadowman39 (author)Kipcorn2017-04-09
You're welcome, and thanks!
random_builder (author)2017-03-21
I might put this in my ball machine. It looks cool, but it uses a bunch of pieces. If I use it, I will give you credit.
Alright, keep in mind you can take many "shortcuts" to reduce the pieces used.
I made it and it works awesome! I quit making the ball machine. It was too normal (normal=boring). I have some ideas for weird ball machines and I might use this lift in one of those.
That's too bad (about quitting the ball machine), but I'm glad the lift works well!
I will be making other weird ball machines with instructions.
True. I will probably make this instead of a boring micro chain lift.
fmartinez22 made it! (author)2017-04-03
this awesome
Shadowman39 (author)fmartinez222017-04-03
Are those paper towers? I don't see a Knex thing in that picture. :-P
MasterMode55 made it! (author)2017-04-02
I made it for me New knex ball machine, but my is so tall that I need help too do it smooth, the counter weight is no helping a lot, can somebody help me?
Shadowman39 (author)MasterMode552017-04-02
Since the larger counterweight didn't help, you could try adding smaller counterweights along the tower, and connect them directly to the crankshafts so there won't be any chance of slipping gears.
MasterMode55 (author)Shadowman392017-04-03
thanks, in Works perfect, i love your creations shadowmano, probably I would include in my ball machine some of your lifts.
Shadowman39 (author)MasterMode552017-04-03
Cool, sounds good!
Hmm, maybe you could use a larger counterweight? :)
I have allredy try it, but then the gears jump out of place
DukDukboy101 (author)2017-04-02
Hmm. Is it possible to make this out of the mini pieces? :D
Shadowman39 (author)DukDukboy1012017-04-02
It should be possible, there'll need to be modifications though.
dzakwanalfatih (author)2017-04-01
o m g
Thanks, and welcome to Instructables!
MisterBukweet (author)2017-03-27
As always... AWESOME build... Runs nice and smooth..
Thanks, I tried to make it smooth as possible! The only thing that isn't so smooth is the sound of the motor.
I have a Knex motor that was given to me... I think it was used in a store display? but it is mighty quiet.. Or we could just gear down a 12 volt motor.. they're fairly quiet.
What kind of motor is it?
Yeah I'd rather use the 12V motors, but I use the green motor in instructions since it's more common.
The Knex Inventor (author)2017-03-28
Great looking lift! Thanks for posting so many great projects, Shadowman39! Favorited :)
Thanks, and you're welcome!
No problem! :)
OfficialKNEXGUY (author)2017-03-23
Nice! A new lift that totally build ahead of time! Great design. Great functionality. Just one question: Are there any other lifts you are going to post instructions on or is this the only one?
Thanks!
-OfficialKNEXGUY
Thanks! As for the other lifts, right now I'm rebuilding the stair-arm lift, and I might post the wheel lift.
ManMister (author)2017-03-21
Great work Shadowman! interesting design. I'm definitely going to make this lift, but change it up a bit with a few ideas I have to inhance it. I'll be sure to share some pictures when it's complete!!
Shadowman39 (author)ManMister2017-03-22
Thanks, and I'm looking forward to see the changes!
About This Instructable
1,603views
14favorites
License:
Bio: On my page you'll find lots of different Knex projects, from ball machine lifts to useful items. I hope you enjoy!  _______________________ Current avatar ... More »
More by Shadowman39:Knex Vertical Jigsaw LiftCitadel Knex Ball Machine Elements - InstructionsCitadel Knex Ball Machine
Add instructable to:
