Knex Very Powerful Weapons
Published
Introduction: Knex Very Powerful Weapons
I know these may not look like much but these are actually short range throwing sticks.
They come in several different sizes and are very powerful.
They all can break through paper.
Pic#1 The sizes.
Pic#2-6 Attachments to increase power.
Pic#7 Damage report, with like 5 throws of each stick this is what happened.
Step 1: Construction
To assemble the throwing sticks you need a 1 of each size rod and any connector. Here is an example.
For the example i used a Gray rod and a Yellow connector.
Pic#1 The pieces.
Pic#2 To connect the pieces hover the gray rod above the connector's middle slot and push down.
Step 2: Damage Report.
With a couple throws of each stick this is what it can do to paper so as you see very strong.
Step 3: Final Project
Your done! now have some fun and i am not liable for damage you do to others.
    • Stick It! Contest
      Stick It! Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    11 Comments
    This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do. 1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable. 2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made! Thanks for your submission and let me know if you have any questions along the way.
    dude, I made the grey one and it hurts like hell!!!
    maybe make it out of steel? Then sell it, and buy enough knex to make a gun?
    throw those medium sized tires at someone...... that'll give a bruise :)
    btw i rated this 0.5* :P
    Again, CONNECTING A PART TO ANOTHER PART DOES NOT MAKE A GOOD INSTRUCTABLE!
    Not really anything here, we all knew that we could throw knex
    Pathetic instructable...
