Knex Vice CKG Bolt Action Gun Instructions
Introduction: Knex Vice CKG Bolt Action Gun Instructions
Hi, these are the instructions to Kinetics Vice CKG and I give him full credit for this awesome gun. I hope that the instructions and pictures are clear enough as this is my first instructable any problems just message me. Please read the image notes if you are unsure on what to do, Anyway lets get building!
If you do build it let me know or post a picture of your version in the comments, feedback greatly appreciated.
This gun shoots about 80 ft with two #64 bands with yellow rods.
Step 1: Layer 1
This is the first layer take note of the blue rods!
1. Layer 1
2. Close up of stock
3. Close of barrel
Step 2: Layer 2
1.Build these panels
3.Close up of barrel
4. This is a broken y connector need this for gun to work properly.
5. Attach these two panels to layer 1 from previous step.
Step 3: Filler Parts
1. Build these
2. Build this, this is the Bullet transfer mech
3. Different view of bullet transfer mech
4. Make these
5. Build this, this is one half of the trigger
6. Build these
7. Build this but do not add that blue rod on the light grey connector.
8. Gather these
9.Add all of what you have just made.
10. Close up of trigger mech
11. Close up of bullet transfer, it does not connect to anything just sits there for now. Notice the two blue spacers above and the grey connector.
12. Close up of magazine area.
13. Close up of stock area.
Step 4: Layer 4
2. Close up of stock area.
3. Close up of barrel area.
4. Again broken y connector
5. Attach to gun.
6. Close up
7. Close up
Step 5: Layer 5
1. Build the final panel
2. Close up
3. Close up
4. Attach to the gun
Step 6: Finishing Up
1. Make the charging handle bolt.
2. Different view
3. Different view
4. Make this, this will be the ram guide. Take note of the silver spacer.
5. Build the firing pin. gray connector taped up also grey connector at end must be there.
6. Make the magazine pusher add a rubber band also.
7. Build these
8. Attach to the gun like so
9. Put the ram, ram guide and charging handle together like so
10. Attach all of this to the gun.
11. Gather these.
12. Add the white rod here.
13. Attach the blue rod here
14. Different view.
Step 7: Banding, Loading and Firing.
1. Gather these bands, the two tied together are #64 bands. These are used to power the gun.
2. Add the large thin band to the bullet transfer system. It connects to the same place the other side of the gun.
3. Add the other thin band to the trigger again it connects to the same place the other side of the gun. And also add the string of two to the ram, they pass through the charging handle.
4. Here is how yours should look.
5. And finally add the magazine pusher. Look on previous pictures to see where the band connects to the gun.
6. Right now the fun part loading and firing, take the mag pusher out and place here.
7. Add a few yellow rods into the mag
8 . Place the mag pusher back into the gun.
To fire the gun simply pull the bolt back until the trigger clicks, then push the bolt forward, and then pull that trigger and watch the yellow rods fly!!!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Honestly, nothing is cooler than coming back to the site and seeing what people have done with the things I worked on in the past. I do apologize for not posting this one, it was definitely one of my best all-round guns but I got turned off by all the criticism telling me that it was too much like the ZKAR. Thank you for posting this, you did a really good job with the pictures, and the internals are spot-on. A quick tip: because the ram is hollow at the very tip, it can possibly break when it strikes the bullet. To fix this, try filling the hole in the gray connector with hot glue, being very careful that none sticks out so that no unnecessary friction occurs within the gun. Great ible!
    I know I'm 3 years into the future, but this gun somehow reminds me of the razorback from call of duty black ops 3
    Thanks so much for your comments really appreciated and yes it is an amazing gun I have built your kinetic rifle and that too is a beast. You are a true genius. I have built the ZKAR and this is in a different league to it. Looks better and is way more powerful. I have had no problems with it breaking as I only have two 64s which is powerful enough for me but the glue does sound like a good idea. Thanks again for commenting really means a lot to me.
    No need for thanks, it means a lot to me to know that what I say means a lot to you. Thank you for the kind words, and thank you for taking the time and effort to do something I should have done. That means a lot to me too.
    Alright I'll get to building it soon. My favorite kinetic build is kinno 2. It's very smooth and powerful for semi-automatic.
    Ok, and I will have to try the kinno 2 I heard it was good.
    sorry about the typos. I was looking at this before class.
    Thanks for your comments and yes you should build this some time. I have just finished building kinetics kinetic rifle which is also awesome however does use lots of parts.
    great job on recreating this gun! I like the guns kinetic made so I will defonitly need to buold this
    Did you get it to work well? When I built it it would not shoot well for the life of me.
