Gather all these bits
Connectors
-x 18 K'NEX Connector 8-way White
-x 13 K'NEX Connector 8-way Black
-x 122 K'NEX Connector 4-way 3D Silver
-x 451 K'NEX Connector 5-way Yellow
-x 115 K'NEX Connector 5-way Light Grey
-x 4 K'NEX Connector 4-way Green
-x 12 K'NEX Connector 4-way Metallic green
-x 36 K'NEX Connector 3-way Red
-x 70 K'NEX Connector 3-way Dark grey granite
-x 8 K'NEX Connector 2-way Light Grey 8
-x 1 K'NEX Connector 2-way straight Orange
-x 5 K'NEX Connector 2-way straight Brown
-x 10 K'NEX Clip with Hole end Dark Grey
End Connectors
-x 12 K'NEX Interlocking clip Bronze
-x 10 K'NEX Clip Blue
-x 1 K'NEX Clip with Splice end Orange
-x 6 K'NEX Clip with Rod end Black
Rods
-x 5 K'NEX Rod 190mm Grey
-x 2 K'NEX Rod 128mm Red
-x 7 K'NEX Rod 128mm Metallic Green
-x 2 K'NEX Rod 86mm Yellow
-x 37 K'NEX Rod 86mm Dark grey granite
-x 30 K'NEX Rod 54mm Dark Blue
-x 7 K'NEX Rod 54mm Metallic Blue
-x 34 K'NEX Rod 32mm White
-x 121 K'NEX Rod 32mm Silver
-x 762 K'NEX Rod 16mm Green or Black
Other
-x 14 K'NEX Gear medium Red
-x 2 K'NEX Crown gear medium Yellow
-x 2 K'NEX Crown gear medium Grey
-x 123 K'NEX Chain link 32mm
-x 11 K'NEX Spacer Silver
-x 27 K'NEX Spacer Blue
-x 4 K'NEX Hub/Pulley Small + K'NEX Tyre Small
-x1 Cyber K’Nex single motor
-x1 Cyber K’Nex double motor
-x1 Cyber K’Nex processor
-x1 Cyber K’Nex IR controller
-x 2 Elastic bands
Total = 1966
Remove these ads by
Signing UpStep 1Build the main body
Image 2 , This image shows the build up to the 10th layer, you will notice there are some gaps. Leave out 4 yellow pieces from the 1st four layers and then leave out four pieces from the 7th layer upwards. There are 2 silve rods fitted on the 2nd layer, these wil be part of the motor mounts.
Image 3 , Build up the next 7 layers and it should now look like this. On the 13 layer fit the silver rods as shown and on the 17th layer fit a black rod end clip.
Image 4 , Build the next 3 layers leaving a gap of 3 for the arms.
Image 5 , It should now look like this.
Image 6 , Build up the next 6 layers as shown. Here you see the mount for Cyber K'nex key card. Leave a gap in the red 3-way connectors from the 2nd from top one right hand side.
Image 7 , Build the final layer as shown. The top is fitted just so you can see how it looks and will now need to be removed.
Image 8 , With the top removed you will see the mounts at the rear, this is for one of the hand held units
Image 9 , Next build the part of the mounts for the tracks.
Images 10 & 11 , Attach to the underside using the 2 silver rods as shown. Ensure the metallic connectors are facing the rear.
Images 12 & 13 , This is how it should look now. Image 13 shows the gaps that were left for the arms and track locations.
Images 14 & 15 , The hatch, make the hatch as shown. The elastic bands are held in place using blue clips. Make sure to use a small amount of tape on the ends of the granite rods to make a good fit in the yellow and brown connectors.
Image 16 , Make the arms. The image shows the left ar, the rightt is just the opposite.
One of the few knex designs I have seen which have almost no holes.
Havr a look here for more http://chinnybeer.co.uk/Slideshow_Stuff/K%27nex_I4.html
Would be nice if the parts list came with photos, some of us aren't word-people ;)
But to be honest I think the best overall drive would be using the front and rear gears, this could still be done keeping the motors in their original positions.
Will have to give it try some time, am working in Sweden at the moment and the K'nex wouldn't fit in the case so had to leave it home lol
