3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build project Enigma Minor
Here's my newest project - Enigma Minor. It's compact, has a lot of paths (5!) and looks cool. The name was suggested in my question "how shall I call my new K'nex ball machine" It looks like project Splat, but I modified it. My add - ons on Splat:
 - 1 extra path: Freefall
 - 2 kinds of path separators: the classic version and the Infinity-Switch
 - 1 new element, that I've designed: the dual ball element. (on path 4 and 5)
 - less pieces!
Good luck with building!
Step 1Pieces
Pieces
Here's the piece count!
Rods:
- Green: 244
- White: 138
- Blue: 289
- Yellow: 64
- Red: 1
- Grey: 9
Connectors:
- Grey 1 – way: 71
- Grey 2 – way: 9
- Orange 2 – way: 25
- Red 3 – way: 144
- Green 4 – way: 29
- Purple 4 – way: 106
- Yellow 5 – way: 137
- Blue 7 – way: 51
- White 8 – way: 35
Spacers:
- Blue: 50
- Gray: 37
Other:
- Blue clip: 4
- Tan clip: 4
- Y – clip: 26
- Blue hinge: 4
- Black hinge: 4
- Red gear: 6
- Chain: 46
- Battery motor with short lead: 1
- Original K’nex balls: 2 or 3
Total: 1537 pieces.
116 comments
1-40 of 116next »
Jul 15, 2011. 2:19 AMCassisDude98 says:
Ik ben trots op Nederland door jouw SUPERRRRRRRRR ballenbaan!!!
Dankjewel!!!
Jul 16, 2011. 3:29 AMCassisDude98 says:
Eigenlijk zou je ook instructies moeten moeten maken voor de Enigma Micro
(hoeveel stukjes gaat die in beslag nemen?)
Alvast bedankt!!!
May 18, 2012. 5:54 AMguitarshredder123 says:
waneer komt de major
May 18, 2012. 7:58 AMguitarshredder123 says:
maak dan een micro,dat lukt vast binnen 2 weken ;)
Feb 18, 2012. 8:30 AMknexman32 says:
coooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooool
Feb 11, 2012. 8:37 AMOrangepanda says:
hey RNB this ball machine is awesome!!!!!!!
this is going to be my first ball ive built so thks for that!
can i keep u updated on how im going because ive never made one before!
thks if i can
=D
Nov 8, 2011. 5:16 AMknexman32 says:
I WISH I HAD ENOUGH KNEX BLUE RODS AND GREEN RODS BUT ANYWAY 5 *****'S
Sep 17, 2011. 10:14 AMZeethesquirrel says:
EPIC imma build it if i have enough blue rods
god i hope i have enough
Jul 12, 2011. 8:43 PMBarfopotamus says:
I just finished the machine (pretty cool, by the way) and everything works but the Spinner. For some reason, the ball seems to fall out a fraction of a second too soon, landing on the track below. Then its momentum carries it in the direction it's supposed to go, however, the Spinner, which is still spinning at high speed, stops the ball and causes it to go backwards off the track. Is the Spinner supposed to carry the ball all the way down until it starts to go back up, or is the ball supposed to fall out but then roll through without the Spinner disturbing it?
Jul 22, 2011. 9:22 PMBarfopotamus says:
I fixed it by replacing the red connectors and y-clips with gray connectors so that the track was slanted.
May 25, 2011. 9:58 AMCrumble says:
how far are you into the enigma major?
Mar 5, 2011. 9:49 AMCrumble says:
if this is an enigma minor, then what is an enigma MAJOR?
Mar 22, 2011. 10:56 AMSorunome says:
Can i see then plz on skype, when you started?
Mar 26, 2011. 1:32 AMSorunome says:
awsome! :) :) :)
Mar 18, 2011. 10:25 AMCrumble says:
Nope, go ahead, i look forward to seeing that :P
Feb 11, 2011. 11:19 AMcool knex13 says:
looks relly good!
10/10
MUST MAKE IT.
Mar 17, 2011. 11:58 AMcool knex13 says:
well....... Later on but I will make it.
Mar 14, 2011. 12:36 PMknexlego says:
is it the big chain not the small
Feb 26, 2011. 3:59 AMk-n-e-x(leaved ibls) says:
i made it and modified it so you can use only one ball
Feb 17, 2011. 11:10 AMSorunome says:
what is the coaster in the background of the first pic?
Feb 18, 2011. 5:47 AMSorunome says:
is that a standart set?
Feb 16, 2011. 8:42 AMbosniaguy says:
got a video?
Jan 11, 2011. 5:47 AMjaydryden says:
Excellent Ball Machine 10/10 - I'm defanitly building this
Jan 3, 2011. 5:28 PMtardis fan says:
Nice job! I'm going to try to make this soon.
Jan 9, 2011. 1:07 PMtardis fan says:
Here are some pictures.
This ball machine is great! I'm glad I spent the time making it. I made a few changes (such as the motor) but didn't change the design.
I also added grey connectors on the maze part, which used to stop the ball.
1-40 of 116next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:RNB(My Blog)
Hi! I'm Ruben, also known as RNB. I'm 15 years and I live in the Netherlands. I'm a Christian. I mainly build K'nex ball machines, although I build sometimes a roller coaster too, for the company Dut...
more »
