Ever wanted to bring out a gun into public? Now you can drag this cart and just slide a switch and fire at you enemy, and also you can use stick to dr...
Build this. You can use any wheel of your choice. But remember to secure it on. 1.Gather these parts. 2.Repeat this pattern with all of the gray rod...
1.Put the ram rod in the barrel like so. 2.Put this assembly on to the cart. 3.Then put the handle on the gray connector. I suggest you do that after ...
Put one end of the rubber band on the ram rod, and put two green rods in front of the barrel, then slip the rubber band between them,like the picture....
To load, you just pull back the ram rod and slide the handle into place. Like a block trigger. Then load a blue rod into the front. To move you just p...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
