Knex Lever-action Shotgun/rifle
915
Posted
Introduction: Knex Lever-action Shotgun/rifle
This is my first instructable so be nice. Anyway this gun features:
1. Removable mags, courtesy of Killer_Safe_Cracker
2. A lever mechanism for ease of cocking (I know it isn't true lever action as it doest chamber a shot like a bolt action).
3. A wide barrel that enables multible shots to be fired like a shotgun.
4. Easy to add parts on the inside due to pins that can be removed easily
Con's
1. low range
 2.low ROF
 3.mags can be hard to preload
Step 1: Outer Body
1+2: make this (part 1)
3. add blue rods
4. make this
5 thread on to part 1
Step 2: Innards
1. Make
2. make
3. attatch
4+5. make this
6. make these
7.put them together
8.slot it in
9. add it on
10. close-up
11. clip the other one on
12. make
13. add
14. put in a green rod
15. add the other part
16. make
17. add
18. make 2 of these...
19. and one of these
20+21 add in order (put the other small one on too after.)
22. make
23.add
Step 3: Trigger
I was lazy here but it should be easy
1-3 various views of the trigger
4. attatch
Note: the broken rod isn't necessary replace the two black hinge pieces with a normal hinge and apply tape
Step 4: Lever and Pin
1. the pin (the string is 1 length approx 60cm long + tying space.)
2-4. the lever
5. don't forget the grey connector
6. insert pin
7. clip on lever
8. add the other shell
Step 5: Stock
1+2. build. The 4 blue spacers can be replaced with 2 small wheels
3. attatch
4. loop the strings over the wheels
5. build and set aside
6. build
7. remember the correct spacer placing
8+9. put them together
10.add it to the body
11. another view
12. make these supports
13. attach them
Step 6: Outer Panels, Sights, and Bands
1+2. make this big panel
3. attatch it
4. put bands on the trigger
5. put bands on the pin
6. make these sights
7+8. put them on
Step 7: Mag
I was lazy again. It uses the mag from the TBAR just without the stuff on top
link: https://www.instructables.com/id/TBAR-Thunder-Bolt-Assault-Rifle-1/step12/Mag/
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    6 Comments
    It doesn't look very pratical nor does look like it was made to actually be good at shooting things but it's an interesting concept as the mech is a bit of a prototype (there hasn't actually been a good lever action rifle made) but after a lot of tweaking it could be good...
    Well...Kind of. Lever actions actually take part in loading the round from a tube mag and that one is just tied to a ram gun. So it's kind of meh.
    The part of this gun that needed to be the most sturdy is really weak. I would make the stock A LOT more sturdy, then put the lever on top of the gun instead,
    I am not liking the position of the lever in this gun; nor exactly the looks of the gun either. Good try though.
