Knex Motor Tune-up Anyone Can Do!!!
7,562
10
36
Published
Introduction: Knex Motor Tune-up Anyone Can Do!!!
Have a noisy K'nex motor!?? I did, and after following this instructable, you will have a motor that is ten times quieter, and runs much smoother, with bit more torque!
This instuctable is created for the average person; that they can do with household supplies, while more professional tools can be used in place of others at will.
Please Leave comments if you like it!...
Step 1: Initial Diassembly
-With your #2 Phillips screwdriver, remove the screws holding the motor case together. They will be hard to "crack" the factory bond the bolt has the first time.
They are all the same size, so no marking of the locations of the screws is required.
-Pull the case apart, it should separate easily!
-snake the motor out, the wires will be somewhat stuck and twisted around near the wire outlet hole.
Step 2: Gearbox Disassembly
Take the output gears out without having the clutch part(spring and other half) of the gears falling out
-PAY ATTENTION on how the red/yellow reduction gears go!! Once you know how they go in your head or drawn on a piece of paper, remove them by sliding them off their shafts.
-Congrats, you now have the motor dissassebled!
Step 3: Gearbox Lubrication and Assembly
Use your pencil to use as a pinpoint oiler! Dip it in the light motor oil and lube!
-Give ONE drop to each shaft!
-Put one "layer" of reduction gears on and dip your pencil into the Vaseline(petroleum jelly) Dab a little bit on the gears. Not TOO MUCH, just right!!
-put the other "layer" on and daub some more jelly on there.
- Put some jelly on the gear teeth and parts the rotate in the motor case on the forward output gear. Reinstall in case.
- Daub some on the same areas as the front output on the side output gear. Reinstall..
-Reinstall the side output gear so all teeth mesh right!
Step 4: Motor Lubrication and Reinstallation
The motor had two main bearings that are always REALLY dry when you dissasemble these motors for the first time. This is what causes most of your noise.
-Put ONE small drop on the front bearing
-Repeat for rear bearing...
-Carefully push the motor in the mesh of the reduction gears. The motor only goes in one way, its trial and error!
Step 5: Final Assembly and Run-down
-Place top half of case back on
-put screws in and softly tighten them down.
TADAAAA!!!!!******************UR done!!
Run it back and forth for a few minutes, you wil notice the difference immediately! It will be a long while till you will need to do this procedure again. So now go and put it to use in your K'nex projects in smooth silence!!
    • Spotless Contest
      Spotless Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    36 Comments
    i found out that you can also use lube like Gel Lube or 3 In 1 lube instead of the jelly
    What do you do if the screw is so broken, hat where thescrew diver normally grbs the screw doesn't exist anymore??
    What I would do is to drill out what is left of the head, then pull the cases apart. You would then be able to grab the sawn off threaded portion of the screw with a pliers and turn it out
    And the cases don't break when you do that?
    what set do you get these motors in?
    ive got about 4 or 5 different sets and not one of these motors
    IMA KILL MAHSELF IF I DONT GET ONE!!
    nah, i wont kill myself, but i do really NEED one of these motors
    Is it also for motors that sound like this? (You have to watch it a bit till you'll see it!)
    Holy Cats Thats a screamer!!!!!. Sounds like one of the bearings on the little DC can motor is begging for a drop of oil. Do the 'ible, and you should have a much quieter motor
    UHoo... it diddn't work!! :(
    Sorry, I just forgot to oil the back of the motor (step 4, pic 2). Now it works veary good! It's one of my quiestets motors! Great! 100*!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Good to see I guessed right. Glad to hear it worked out in the end! Have fun now iwth your quiet motors! Care to post a "After" vid????
    I think, that I won't, because I'm busy building a ball machine right now, but they are a bit quieter than the first lift in this ball machine (mine!!!). Of course you can watch the hole vid! :)
    I have 2 of these "screamers". :)
    Thanks my motor sounded like a banshee. Now i can barely here it!
    Thats great to hear (or NOT, pun not intended) Glad it made your motor run better!
    Thanks the motor in my screaming serpent wasn't working. WHen i did this it worked very well ty. 4*
    i have another motor(i have 2) kinka like this but it has a short cord and the other has a long cord and the longer 1 is the same the boxer and shorter 1 is different if you want i can get some pics
    hmm.... interesting.... a couple of things really 1) I am pretty sure you should use silicone lubricant on plastic gears, rather than motor oil 2) you can never really have too much lubrication....
    This is meant for people who dont have a whole toolbox and box of lubricants at home. I in fact have silicone grease and oil, but 90% of people have Petrol Jely and a small bit of motor oil aorund. Petrol Jelly should NOT harm the plastic gears at all, however, if they were made of rubber, different story. I agree with you, but in this case, yes, in the knex motor you can vae too much. Dont want to glob everything up when its going to all get over you, your knex, and your mums carpet!!
    I guess i see your point, however silicone lube isn't exactly expensive, and a tube lasts ages. I didn't know those motors took to leaking grease, have not touched my knex in years.
